Cannot Upload
- Cannot Upload
Re: Cannot Upload
23-11-2011 1:13 PM
Re: Cannot Upload
23-11-2011 1:44 PM
Re: Cannot Upload
23-11-2011 2:06 PM
Quote from: Majority >Upload speed achieved during the test was - 477 Kbps
Doesn't seem bad, at least not for 20CN, which is all they have in my area.
Quote from: Majority Additional Information:
Upstream Rate IP profile on your line is - 588 Kbps
But I've never seen an upstream IP profile reported. Is this something to do with this newfangled 21CN?
Re: Cannot Upload
23-11-2011 2:14 PM
Re: Cannot Upload
24-11-2011 4:24 PM
Re: Cannot Upload
24-11-2011 4:28 PM
Quote from: Joanne Are you using the test socket?
Quote from: Majority Really do not know where or what that is?
Click the underlined test socket link in my post and it takes you to a picture of it.
Jojo
![Smiley Smiley](/html/@39650D28FE4EA73A5BA77CFD0A477003/images/emoticons/smiley.gif)
Re: Cannot Upload
24-11-2011 4:33 PM
Re: Cannot Upload
27-11-2011 4:19 PM
Thanks,
Re: Cannot Upload
27-11-2011 5:26 PM
Quote from: Majority Hi, I have checked the main socket into the house. There is only one connection.
Are you trying to say your house does not have a master socket with a detachable faceplate? But you do have more than just the one phone socket??
Re: Cannot Upload
27-11-2011 7:29 PM
Thanks,
Re: Cannot Upload
27-11-2011 8:15 PM
Re: Cannot Upload
27-11-2011 9:43 PM
Any nice people here still?
Thanks,
Re: Cannot Upload
27-11-2011 9:52 PM
Plusnet would be unlikely to request an engineers visit until your basic wiring checks have been performed as the last thing they would want is an irate customer with a large BT bill in his hand.
Their check procedure is to try and avoid this situation.
Re: Cannot Upload
28-11-2011 12:33 AM
Thanks,
Re: Cannot Upload
28-11-2011 6:19 AM
Do you just have the one computer, or more than one which is experiencing this upload problem?
(Seems unlikely but could it be a problem with the computer, eg. security software?)
Given the line stats and Speedtest.net results seem to look okay, I would suggest to try a different router given the known issues with the TG585v8 router. (You may have inadvertently uncovered some obscure compatibility bug or the unit you have is just defective....)
I think you previously tried your old BT hub but couldn't get it to work. Can you confirm which model of BT hubs you possess?
Were you able to actually store/save your plusnet username & password into the hub, or was it rejected when you tried to type it in ?
I know the 2.0 Type A model used to work fine on Plusnet last time I tried one a few years ago, and I believe the later 2.0 Type B should also accept plusnet plusdsl.net and plusdsl2.net usernames too. http://www.psidoc.com/showthread.php/248-Unlocked-Home-Hub-2.0B?p=1348&viewfull=1#post1348 Older Home Hubs v1.x may not work with PlusNet.
Otherwise, PN could consider providing one of the new/better TG582N routers, currently undergoing user trials, for you to try?
