Can't log into Hub manager
cwardle16
Can anyone help me? I'm getting an orange flashing light on my router, but I get this message when trying to log into the hub manager.
I'm unable to post a photo of the error message I get! But it says this site can't be reached, web page might be temporarily down or it may have moved permanently
Tags (1)
22 REPLIES 22
Fixes: 357
Re: Can't log into Hub manager
@cwardle16 Welcome to the forums. Which Hub have you got? How long have you been with PN?
cwardle16
We have plus net hub one and are new customers
Fixes: 357
Have you ever been able to log into the Hub, and how 'new' is new? If you have the Hub1 you must have been here a little while, as brand-new customers receive the Hub2.
cwardle16
No we received this hub last week and got the connection email last night
Fixes: 1,491
ADSL customers get the Hub1 @jab1
Fixes: 357
@dvorak Didn't realise that, so thanks.
@cwardle16 Try pushing a paper-clip or similar in the reset hole on the back of the hub and holding it closed for 30 seconds or so, then release and let the Hub reset.
cwardle16
Tried to reset. It goes blue but then flashes orange. My husband doesn't think they've connected us yet, despite the email
Fixes: 357
OK. What day did they say they would connect you? If it was today, that could be any time up to 23.59.59 as the 'system' has to fully update.
Fixes: 466
@cwardle16
You should be able to log in to the hub regardless of whether you have Internet access.
How are you trying to do this? You should enter 192.168.1.254 in the address field on your browser. Are you connecting over wireless or Ethernet? If you are using a computer the address field is at the top of the browser page. If you also have a search field provided by the likes of Google then this will not work for logging in to the hub.
Fixes: 357
Just beat me to it, @Baldrick1 . I was just amending my previous post to make this point. 😉
cwardle16
Hi @Baldrick1 I'm putting the hub manager address into the internet address field on my phone. I haven't tried my laptop as I have no internet, so didn't think it would work.
Fixes: 357
@cwardle16 As @Baldrick1 says, you don't need internet access to log in to the Hub. Try the laptop - phones can be a bit flaky,
cwardle16
Just tried the laptop and I'm still getting an error message
'This site can't be reached'
I'll keep trying and if we get no joy by tonight I'll phone them.
Thank you all for your help
Fixes: 357
If you are merely trying to log into the Hub, is it powered on and plugged in correctly? That message suggests otherwise, if you are entering 192.168.1.254 into the address bar.
