Can't connect to plus.net
DandD
Hi, Help please. This morning I tried to access Plus.net from my Windows 10 PC and failed. Never had this issue before. Got this message from MS Edge:
Hmmm… can't reach this page
The connection was reset.
Try:
ERR_CONNECTION_RESET
Firefox gave this message: Secure Connection Failed
An error occurred during a connection to www.plus.net. PR_CONNECT_RESET_ERROR
Error code: PR_CONNECT_RESET_ERROR
The page you are trying to view cannot be shown because the authenticity of the received data could not be verified.
Please contact the website owners to inform them of this problem.
19 REPLIES 19
adamwalker
Fixes: 223
Re: Can't connect to plus.net
That's really odd, we're not aware of any issues that happened yesterday.
Did/does the same thing happen on other devices if you have any and is it still the same after you try deleting your browser's cache of cookies and temporary internet files?
Adam
 Adam Walker
stephen1510
I have the same problem on Windows 11.
Tried four different browsers, as well as clearing caches.
It's OK on Mobile Data, but not when going through the router.
Obviously I can connect to community.plus.net
James30
Fixes: 32
@stephen1510 - Daft connection but can you check the date and time is correct at the bottom. Also have you tried another device on Wi-Fi like your phone?
James - Plusnet Sheffield
stephen1510
I checked all of that before I posted.
So, reset the plusnet router. Now I can access plus.net from my Windows 10 PC (ethernet) and my mobile (wifi) but still not from my Windows 11 PC (ethernet). Tried a reboot but still no joy.Temporarily disabled anti-virus - same problem.
At least I have some means of accessing my account now. Very puzzled though, as no other site gives me a problem. Can't think what to try next.
James30
Fixes: 32
Got you. Without stating the obvious then, it's got to be a computer issue that perhaps other users can help with? There's plenty of places the issues could be, I've seen strange issues where the server is blocking your IP bit that can't be the case if it's working on another pc through your router.
We're looking at cookies, cache, extensions, VPN'S, proxy settings, antivirus and firewalls. I could think of a scenario where other network tech giving out duff DHCP address namely the DNS address do you have boosters, powerline adapters, switches connected any ware on the network wirelessly or wires?
Is it the exact same error message "ERR_CONNECTION_RESET" you get, perhaps you could screenshot MS edge showing the URL and the error page?
What happens when you try to access Plusnet with it's IP by paste 212.159.9.2 instead of plus.net into the address bar?
stephen1510
Yes, really strange that this is the *only* site that gives me this problem.
Tried using the IP address. Firefox screenshot attached.
Edge, Chrome and Opera give a similar error - Connection Reset
No proxy is used. Disabled AV and firewall. No difference.
stephen1510
More info
Tried
ping 212.159.9.2
request timed out
Then
tracert 212.159.9.2
gets as far as 84.93.232.58.plus.net and then times out
James30
Fixes: 32
And we're sure it's working on another device on same router and no cashed or saved perhaps?
Fixes: 145
@stephen1510
212.159.9.2 will not respond to ping or traceroute
In a windows power shell try Test-NetConnection 212.159.9.2 -Port 443
You should get the following if the test works
ComputerName : 212.159.9.2
RemoteAddress : 212.159.9.2
RemotePort : 443
InterfaceAlias : <This will be WiFi or Ethernet>
SourceAddress : <your PC IP Address>
TcpTestSucceeded : True
HTH, Dan
stephen1510
Yes that Powershell command works fine on my Win11 PC.
Tried again to connect to plus.net on my ethernet Win10 PC, and a Win10 laptop connected by wifi.
Cleared browser cache, restarted browser. Connects OK on both.
One odd thing on these, is that the plusnet homepage comes up, then goes blank and then re-appears. Don't know if that is normal as I can't try on a different router atm.
Fixes: 241
Take a look at this - Fix err_connection_reset in Windows 11 & 10 Like This (windowsreport.com)
Is there a VPN involved here?
stephen1510
So, I've been away for a few days with the Win11 PC turned off.
Started it up and I was able to access plus.net
Tried again a few minutes later and I had the error message again.
It must be something that gets loaded during startup ...
I had already uninstalled BitDefender so knew it wasn't that.
I have NordVPN, but had the message even when not connected to their servers.
Decided to uninstall NordVPN and restart the PC.
Able to connect to plus.net straight away and some time later. Hooray!
Re-installed NordVPN, rebooted and so all is working as it should be. I really don't understand why that program should have caused a problem with just that one website.
Thanks for the link about VPNs I'll take a look at that.
Fixes: 241
The link is not about VPNs, but the issue you experienced ... which points to VPNs as a potential culprit.
Seems that it might have been the cause of your issue.  The fact that it now works after reinstallation does not mean that it was not the issue.  A clean reinstall can work wonders.
stephen1510
Very interesting article. I had tried most of the possible solutions that are suggested there.
In the end, it was just a question of applying a bit of logic; it had to be something on just this particular PC and only kicked in shortly after a boot.
Funny that it was plus.net that I couldn't access, being my current internet provider.
Anyway, thanks to everyone for their input.
I hope my experience will help anyone in a similar position.
