Can I got a fixed IP Profile somehow?
- Can I got a fixed IP Profile somehow?
- « Previous
- 1
- 2
- Next »
Re: Can I got a fixed IP Profile somehow?
04-03-2011 5:50 PM
Download speedachieved during the test was - 845 Kbps
For your connection, the acceptable range of speeds is 800-2000 Kbps.
Additional Information:
Your DSL Connection Rate :2304 Kbps(DOWN-STREAM), 832 Kbps(UP-STREAM)
IP Profile for your line is - 1500 Kbps
ADSL Link Downstream Upstream
Connection Speed 2304 kbps 832 kbps
Line Attenuation 62.0 db 31.5 db
Noise Margin 6.8 db 8.0 db
Message 16 of 17
(210 Views)
05-03-2011 5:05 PM
Quote from: Joanne Your upstream is uncapped, so if you were to cap that again it may give your downstream a better rate.
You currently have interleaving off which could be compromising your stability, so we could switch that on and see if it helps.
Your exchange is due to be upgraded to ADSL2+ at the end of this month so we could put you on that and put you on no DLM.
The other day when I posted that message I did it after speaking to one of the leading faults guys after we'd analysed your line. I don't want you to get disappointed going through the faults process expecting to get a better performance while keeping your line fast path and the upstream uncapped. Would it severely impede your use of your service if your upstream was capped? The chances are that the first thing the faults team will do is turn interleaving on. I posted those options to try to save you some time and more frustration. As for the line being banded this is only possible on ADSL2+ which your exchange is not yet capable of.
Jojo
Message 17 of 17
(210 Views)
- « Previous
- 1
- 2
- Next »
