CHAP Authentication Problem
- CHAP Authentication Problem
18-03-2008 11:29 AM
Rebooted it and reset it a number of times.
Any ideas?
Re: CHAP Authentication Problem
18-03-2008 11:40 AM
I've run a couple tests on your line and I'm seeing you as having synchronisation with the exchange but I'm not seeing any failed login attempts. What happens if you manually go into your router and reenter the username and password details?
18-03-2008 11:40 AM
If it's not that then I'd firstly check to make sure that the user name and password are correctly set in the router. You could then try powering everything down for 30 mins and reconnecting as you may have a stale session.
Failing all of the above - give support a call.
18-03-2008 11:54 AM
anyway it works now. not sure why. thanks tho
18-03-2008 11:56 AM
18-03-2008 11:59 AM
18-03-2008 12:11 PM
18-03-2008 12:13 PM
18-03-2008 12:13 PM
Quote from: Chris We've just had a surge of authentication calls, normally when this happens there is an associated BT MSO (Major Service Outage) but we haven't received on yet. The amount of calls coming in are slowing down so the main issue seems to be clearing up. I'll let you know if we find out more details of what the problem was.
I had a phone call from my friend saying that they couldn't get a connetion etc so I did a tracerout and got theses figures.
Find route from: 192.######
to: plus.net (212.159.8.2), Max 30 hops, 40 byte packets
Host Names truncated to 32 bytes
1 192.#######(192.###### 😞 1ms 0ms 0ms
2 lo0-plusnet.pte-ag1.plus.net (195.166.128.64 😞 13ms 13ms 13ms
3 ge0-0-0-403.pte-gw2.plus.net (84.92.4.2 😞 14ms 13ms 14ms
4 te2-4.pte-gw1.plus.net (212.159.1.101 😞 165ms 106ms 187ms
5 atm1-0.ptb-gw1.plus.net (212.159.1.89 😞 20ms 24ms 23ms
6 vl427.pih-gw3.plus.net (212.159.1.123 😞 20ms 23ms 20ms
7 if25.pih-lb03.plus.net (212.159.0.17 😞 20ms 30ms 25ms
8 if25.pih-lb03.plus.net (212.159.0.17 😞 21ms 70ms 22ms
• Trace completed 18/3/08 11:32:04 •
Start: 18/3/08 11:45:33
Find route from: 192.168.0.3
1 192.#### (192.####): 1ms 0ms 0ms
2 lo0-plusnet.pte-ag1.plus.net (195.166.128.64 😞 15ms 15ms 20ms
3 ge0-0-0-403.pte-gw2.plus.net (84.92.4.2 😞 14ms 13ms 13ms
4 te2-4.pte-gw1.plus.net (212.159.1.101 😞 15ms 12ms 12ms
5 atm1-0.ptb-gw1.plus.net (212.159.1.89 😞 19ms 19ms 18ms
6 vl427.pih-gw3.plus.net (212.159.1.123 😞 21ms 22ms 21ms
7 if25.pih-lb03.plus.net (212.159.0.17 😞 23ms 20ms 36ms
8 if25.pih-lb03.plus.net (212.159.0.17 😞 19ms 19ms 20ms
• Trace completed 18/3/08 11:45:36 •
Hop 4 in the first trace caught my eye.. Could this be the reason?
18-03-2008 6:21 PM
High ping times within transit can be normal and in the majority of cases are to be expected. You have to take figures from end to end into account.
The job of these intermediate routers is to route data and responding to pings is normally treated as low priority.
