Bt hub 2 issue
- Re: Bt hub 2 issue
Bt hub 2 issue
07-07-2022 9:04 PM
Hi all,
I’ve had my br hub 2 router connected to plusnet for 18 months but today the orange light stays on. I’ve done the following:
Checked with neighbours and internet is fine
Carried out a factory reset
Connected to hub via laptop and Ethernet
Reset username whilst DSLcable is disconnected
Then reconnected cable
Orange light still stays on… can anyone help?
Message 1 of 2
(717 Views)
1 REPLY 1
Re: Bt hub 2 issue
08-07-2022 5:04 AM
Sorry if this is asking the obvious, but do you have a Plusnet router that you can try?
Do you have dial tone at the master phone socket with a wired phone?
Message 2 of 2
(681 Views)
