Browser history
- Browser history
Browser history
13-04-2013 9:52 PM
Hi all,
Recently joined on unlimited tariff. Can I view the browser history of other wifi connected devices via the router or any other method?
Regards,
Paul.
Regards,
Paul.
Message 1 of 7
(7,745 Views)
6 REPLIES 6
Re: Browser history
13-04-2013 10:05 PM
No, I do not think so, but you can set parental controls to block/redirect websites you input.
Message 2 of 7
(6,950 Views)
Re: Browser history
13-04-2013 10:30 PM
You could try this:
http://npr.me.uk/telnet.html#visits
But check that it's not making browsing slower.
Message 3 of 7
(6,950 Views)
Re: Browser history
13-04-2013 10:35 PM
Not exactly something your average Joe can do though
, unless OP is not an average Joe...
Just tried it, does appear to reduce speeds by a considerable amount.
Message 4 of 7
(6,950 Views)
Re: Browser history
13-04-2013 10:38 PM
That depends if a typical 'Paul' is better than an average Joe ?
Message 5 of 7
(6,950 Views)
Re: Browser history
14-04-2013 11:39 PM
Not sure if I'm typical or average, but thanks for your replies!
Message 6 of 7
(6,950 Views)
Re: Browser history
15-04-2013 12:08 AM
You could use OpenDNS and open an account with them (free). Set up stats in the dashboard and it will log all the history of all your devices albeit you won't be able to assign the sites visited to individual clients.
Message 7 of 7
(6,950 Views)
