Broadband speed very low.
Squib
Could someone please check my line , as my upload speed is about 3 meg.
3 REPLIES 3
Gel
Aspiring Champion
Fixes: 27
Re: Broadband speed very low.
You need to carry out some self checks from links below.
Check capability of your line by using the BT Wholesale link.
Squib
Did speed test , download  speed 5.1 (not good enough)
EmilyD
Fixes: 117
Hi @Squib,
I'm sorry that your speed is poor and for any inconvenience that this is causing you.
I can see that you have now discussed this with an advisor and an external fault has been found when the line was tested. This has been raised to our suppliers for further investigation and their estimated response time is by the 31st of July. Our faults team will be in touch once we've received an update from our suppliers.
 Emily D
