Broadband speed slow - Customer support speed = SLOWER STILL
- Re: Broadband speed slow - Customer support speed ...
- « Previous
- Next »
Re: Broadband speed slow - Customer support speed = SLOWER STILL
08-11-2009 7:23 AM
@shutter why not get a i-plate/BT accelerator socket it could help I think for problems lines Plusnet my let you have 1 free or order 1 from BT you can get them free plus p&p £5
They are easy to fit on to the master socket but it doesn’t matter if your router connected elsewhere in your house it will still work.
Kind regards
Puddy
Kind regards
Puddy
Message 61 of 64
(328 Views)
09-11-2009 7:24 AM
I have fitted this master face plate from ADSL Nation Ltd. Seems to have cured noisy BT line. Have found it well worth investment.
http://www.adslnation.com/products/xte2005.php
Message 62 of 64
(328 Views)
09-11-2009 10:00 AM
Shutter, The suggestion in the last post requires your router to be plugged in to the master socket. Just plugging in to the master socket without the expense of one of the filtered face plates would give you an improvement as you have already proved.
Message 63 of 64
(328 Views)
09-11-2009 11:16 AM
John, it's all sorted, info later. (That arrangement, plugged into Master, is not ideal to his situation).
Message 64 of 64
(328 Views)
- « Previous
- Next »
