Broadband speed is halved
Dannzann
Since the beginning of my contract I have got 50+ MBs and now that I'm into my last 6 months the speed has never exceeded 20 MBs. Can somebody please look into my account and let me know why this is the case.
Cheers
2 REPLIES 2
Fixes: 357
Re: Broadband speed is halved
@Dannzann I have noticed a comment by one of the PN Help Team that they are a bit busier than normal, so if you can run through the guide below, maybe other Community members can help you a little quicker?
For Community members to be able to help, information from these two sites, as screenshots:-
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub would be a good starting point.
For the Hub One -
For the Hub Two -
adamwalker
Fixes: 223
Hi @Dannzann
I've just been taking a look into this for you, line tests don't show signs of any issues so I'm wondering if this might be specific to WiFi, if that's how you usually connect your devices I can log into the router from here if you like and run a smart channel scan which should put the router on the best available channels for us.
Doing that will cause the wireless signal to drop out briefly for two minutes so we need to ask for your approval for that reason first.
 Adam Walker
