Broadband speed deteriorating
- Broadband speed deteriorating
Re: Broadband speed deteriorating
14-11-2014 9:14 PM
15-11-2014 11:12 AM
So it's just why the sync speed isn't at the top to give you a 7Mbps profile - I'd expect you to notice the extra 0.5 Mbps improvement - and Upstream Interleaving still on - that bit is part of this ongoing 20CN issue.
15-11-2014 11:36 AM
15-11-2014 3:26 PM
15-11-2014 3:42 PM
Quote from: Anotherone Are both the filters that you are currently using the two new ones that came with the TG582n?
No, both the filters are the old ones, but are swapped over from the original configuration
15-11-2014 4:41 PM
17-11-2014 12:05 PM
Done:
Quote from: Anotherone Ok. Could you do a graceful Disconnect, stay off for 10 minutes and replace both filters with the new ones.
Uptime: 0 days, 0:02:15
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 448 / 7,808
Data Transferred (Sent/Received) [kB/kB]: 13.46 / 16.30
Output Power (Up/Down) [dBm]: 11.9 / 19.9
Line Attenuation (Up/Down) [dB]: 12.0 / 19.5
SN Margin (Up/Down) [dB]: 28.0 / 6.1
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Framing (Local/Remote): 0 / -
Loss of Signal (Local/Remote): 0 / -
Loss of Power (Local/Remote): 0 / -
Loss of Link (Remote): -
Error Seconds (Local/Remote): 0 / -
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): - / 0
I seem to have got a slight increase in sync speed ...
17-11-2014 1:04 PM
17-11-2014 5:26 PM
Well kbturner, that slight increase of 32kbps is nothing and at least proves that all your filters are OK..
There is one remaining check you could do - the extension socket. No need to disconnect the modem/router for this or unplug anything.
Remove the lower faceplate from this "extension" socket - keep an eye on the SNRM - whilst I'm not expecting it to change, it may increase.
Then remove the 2 screws from the rear plate so you can have a look behind. As it's an old style, it should have two screw terminals marked A & B.
Whilst there shouldn't be any wires connected to them there may be, or there may be a disconnected cable tucked behind.
In either case, describe any wires and cable you can see and precise colours and what they are connected to, if indeed there are any.
19-11-2014 4:07 PM
Quote from: Anotherone Remove the lower faceplate from this "extension" socket - keep an eye on the SNRM - whilst I'm not expecting it to change, it may increase.
Done.
There are no wires/cables behind the rear plate, either connected or disconnected, to the (three) terminals there.
Here's the latest stats:
Uptime: 2 days, 4:04:06
Data Transferred (Sent/Received) [MB/MB]: 75.79 / 495.81
SN Margin (Up/Down) [dB]: 28.0 / 6.3
Error Seconds (Local/Remote): 192 / -
CRC Errors (Up/Down): 0 / 266
HEC Errors (Up/Down): - / 448
What next?
(PS Do you know anything about this product? http://www.getfullspeed.com/)
19-11-2014 4:55 PM
Stats are interesting, only up for 2 days and 4 hrs+ , did you power off? But you've now got no upstream FEC errors at present.
What next? I think Tony will come and have a look with a view to investigating the cause of you not getting 8128.
19-11-2014 5:11 PM
Quote from: Anotherone Stats are interesting, only up for 2 days and 4 hrs+ , did you power off?
I did this on the 17th:
19-11-2014 5:27 PM
19-11-2014 5:41 PM
Quote from: Anotherone Sorry, a lot of water has gone under the bridge ...
Tell me about it!
You and I have been chatting now for a full two weeks - and I'm very grateful for all your efforts - but I'm not seeing much sign of any improvement, and I'm beginning to lose heart.
What's your prognosis - am I going to be able to get back to the sort of performance I was seeing before this problem arose?
19-11-2014 6:09 PM
