Broadband not working
- Re: Broadband not working
29-01-2022 9:49 PM
29-01-2022 9:52 PM
Dial 17070 option 2.
29-01-2022 9:55 PM
29-01-2022 9:57 PM
Which Hub do you have?![]()
29-01-2022 9:59 PM
29-01-2022 10:01 PM
So you've had it for a while? What is the model number?
29-01-2022 10:04 PM
The model number is 2704N
Thanks🙂
29-01-2022 10:04 PM
29-01-2022 10:06 PM
29-01-2022 10:08 PM
OK, a Hub0 then. I'm not that familiar with them, so will leave this topic to @Townman , otherwise I may give you incorrect information.
29-01-2022 10:11 PM
29-01-2022 10:27 PM
At this juncture the model of the hub is not overly relevant. Until we know if there is a dial tone and no noise there nothing we users can do to assist. Possession of a telephone hand set ought to be mandated in the T&Cs, but it is not. Therefore the user will need to wait until support pick up the issue here, phone them support centre or (if they have a mobile phone) use the SMS phone line test service as documented in the user portal.
30-01-2022 7:40 AM
Fork out £10 for a handset; may also come in useful if the mobile network goes down at some time.
30-01-2022 4:37 PM - edited 30-01-2022 4:39 PM
Thanks a lot for for getting in touch @chrisev22 and I'm really sorry to see how intermittent the line has been lately. Testing the line this afternoon has found that the target SNR is already quite high - 15dB,which is supposed to counteract instability. My ADSL test didn't find any underlying faults with the service, though it was recommended that we turn on interleaving to try and stabilise your line further.
This has now been done, so please monitor your connection over the next week or so and let us know if things are still not improving. We may need to arrange an engineer visit.
I'll pop my test results below to see if our community members would like to make any further suggestions here. I suppose the next course of action, if interleaving does not improve your service, would be to modify the connection profile from "standard" to "stable".
Apologies for the delayed response from Plusnet as well @chrisev22 - flying solo on the forum this weekend!
30-01-2022 5:10 PM
15dB is aggressive DLM management and that does not happen for no good reason.
No fault found WHEN TESTED could imply an intermittent fault, typical of wet joints - which come and go and are best identified by running QLTs ... but that requires a telephone handset!!!
