Broadband issues
Ragismiks
Broadband issues
Hi there
Since I've become an plusnet client our broadband has been shocking. I've been in touch with support and <Redacted> was rseeting the system for me and it's just diabolical. My daughter can't even watch cocomelon on netflix without it buffering every 5mins. I've just received an email after my 14days showing some random speeds etc, my speed doesn't even meet half of the speeds etc email says. Even your own support guy said its shocking.
I want to cancel it as the broadband is unusable. My kids has to use hot-spot to run their Xbox or PC. Internet after midnight is even worse. I've done speed tests and it's around 4-5mb.
Moderator's note:
Personal information removed from a public forum (to an area that staff can see).
53 REPLIES 53
Ragismiks
Re: Broadband issues
Screenshot_20240710_131157_Samsung Internet.jpgScreenshot_20240710_131212_Samsung Internet.jpg
Ragismiks
Fixes: 387
@Ragismiks There is obviously a fault somewhere, which the PN 'reset' pbviously hasn't fixed. In order for other Community members to possibly help, can you follow the below -it will give us asolid starting point.
As an aside, your 'ping' is atrocious, and whatever is causing it is probably a major contributor to your isse.
BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS'. This test is recommended to be performed with only one device connected.
For the Hub One -
For the Hub Two -
Fixes: 480
@Ragismiks
You say: my speed doesn't even meet half of the speeds etc email says. You then report speeds between 6 and 8 Mbps.
Can you confirm your actual guaranteed speed as it sounds that you are either on a very long FTTC line or ADSL. You also say that your family is streaming from Netflix and gaming on an Xbox.
Are you ensuring that none of these are running at the same time as you are conducting a speed test? To be honest, regardless of whether or not you have a fault, based on your information I would question whether your current connection is capable of providing the speed required to satisfy your family needs.
Fixes: 387
@Baldrick1 Until we get a response (if we do) to my post above, I think the ping results provided are part of the problem. Maybe we wait and see?
Fixes: 480
@jab1
We obviously need to wait for a response to your post  However, I also think it worth testing the assumption that there is a fault. The ping could be due to buffer bloat caused by other running services.
Fixes: 387
Agreed, @Baldrick1 . If the OPs network is running concurrent intensive services though, on an FTTC service, then their results could be expected.
markhawkin
Champion
Fixes: 22
@jab1
There are a couple of clues in the "Fast" results.
An upload of 1.8Mb/s suggests VDSL
If the location of Milton Keynes is correct, as I recall due to the way the city was originally built and phone wires provided it's a place with more Internet speed issues than most.
I wonder if the previous service was Virgin Media (which obviously wouldn't have phone line related issues).
Fixes: 387
Cheers, @markhawkin
markhawkin
Champion
Fixes: 22
@jab1
Having had a play with the Think Broadband map, if I lived in Milton Keynes I would either be looking at a supplier on CityFibre or Virgin Media.
Openreach FTTP is a bit limited there.
Fixes: 387
But the user appears to be on FTTC?
Ragismiks
Ryan (plusnet) technician done the BT checks on m my behalf and everything was fine. He said my router was limited to speeds etc hence it got reset but it hasn't made a difference.
My guaranteed speed was meant to be 13mb
When he done the checks he said the broadband isn't ever used much as in not much is connected just general things. No xbox or pcs etc was running at the time of the test.
I live in a village near Milton Keynes.
We had sky before, sky worked fine, I was getting my guaranteed speeds etc but the price they charge was outrageous. Plus net was half the price for the same guaranteed speeds.
They checked the phone line aswell said everything okay, router location was good.
I just can't work out why it's so rubbish, even the technician said he can't understand why it's so bad. I'm still in my reset period, 2 days left but it's not got better even in slightest.
Ragismiks
I'm at home on my own at the moment, literally everything is switched off, I can't even open my BT speed test as broadband is so slow.
I work at nights and most nights I need to use my 4g on phone to run laptop or phone to even get simple things like emails as with WiFi nothing comes through.
Fixes: 387
@Ragismiks Complete as much of my request above that you can - as I said, we need a little more detail.
