Broadband fault? Low speed
Steevo
After seemless broadband for quite some time, this evening I've come across a slow speed issue.
Stats from Router below and BT wholesale screenshot attached.
Your Plusnet adviser may ask you for the following information:
1 - Product name: Plusnet Router
2 - Serial number: N7182281B011137
3 - Firmware version: 7.275.11_F2704N_Plusnet
4 - Board version: F@ST2704N
5 - Mode ADSL
6 - Uptime: 5 days 10:51:02
7 - Data rate: 768/3591
8 - Maximum data rate: 776/3700
9 - Noise margin: 6.0/3.6
10 - Line attenuation: 39.6/63.0
12 - Data sent/received: 3.2G/395.3M
20 - Broadband username:
21 - Wi-Fi network/SSID:
22 - Wi-Fi connections: Enable(802.11 b/g/n(up to 300 Mb/s))20 MHz WPS enabled
23 - Wi-Fi security: WPA2
24 - Wi-Fi channel: 6
25 - Firewall: Default
26 - MAC Address: d8:7d:7f:a1:1e:19
27 - Software variant Version 1.0
28 - Boot loader: 7.275.11
3 REPLIES 3
adamwalker
Fixes: 206
Re: Broadband fault? Low speed
Hi Steevo, sorry to hear that there's an issue. I've just been running some diagnostic tests to look into this from our side and we're not seeing any obvious causes for the issue.
If you haven't already it would be a good idea to try a speed test over a wired connection to the router. Here are some troubleshooting checks you could try running too: https://www.plus.net/help/broadband/connection-troubleshooting/
 Adam Walker
Steevo
Thanks Adam.
I found my internet had completely dropped out earlier as the Internet light was missing on my router.
Called support and was advised the connection wasn't in sync. New router has now been ordered so should be here in 3-5 days apparently.
adamwalker
Fixes: 206
OK, cheers for the update and I hope that resolves the issue, please do keep us posted.
 Adam Walker
