Broadband dropping out
AK82
My broadband has been dropping in and out over the past few days and now it’s totally given up the ghost 😤
Moderator's Note
This topic has been split off from another topic and edited to aid clarification.
2 REPLIES 2
Fixes: 472
Re: Broadband dropping out
@AK82
Report a fault, see https://www.plus.net/help/report-a-problem/broadband/#broadband
Fixes: 241
Checking the phone line might short circuit the process!
Broadband is not going to work well if the "phone" line is not working properly.
Please perform a quiet line test - dial 17070 select option 2 using a phone plugged into the test socket behind the face plate of the master socket (ideally this should be a corded phone). The line should be silent. A noisy phone line (or no dial tone) will have a marked adverse impact on the performance of broadband.
If the line is noisy or there is no dial tone, then a PHONE LINE fault needs to be raised with your phone provider. If this is PlusNet, you can report a fault on line using the button below. NB: You need to put your LANDLINE NUMBER after "PHONE" [missing instruction].
