Flaky connection after minor speed increase
SilverE
New Plusnet 2 router on 13 April on old 40Mbps connection before upgrade to "full" FTTC. That happened on 17 April and speed increased to 54Mbps, took a day to settle then ran continuously until 30 June. Speed then increased to 57Mbps and there have been four line-drops since then, three today. What's going on?
This is the log:
21:47:12, 04 Jul. DSL Link Up: Down Rate=57123kbps, Up Rate=20000kbps; SNR Margin Down=5.9dB, Up=6.4dB
21:46:31, 04 Jul. DSL Link Down: duration was 18121 seconds
16:44:38, 04 Jul. DSL Link Up: Down Rate=57601kbps, Up Rate=20000kbps; SNR Margin Down=5.9dB, Up=6.4dB
16:43:57, 04 Jul. DSL Link Down: duration was 1861 seconds
16:13:04, 04 Jul. DSL Link Up: Down Rate=57410kbps, Up Rate=20000kbps; SNR Margin Down=5.8dB, Up=6.3dB
16:12:27, 04 Jul. DSL Link Down: duration was 40290 seconds
05:01:05, 04 Jul. DSL Link Up: Down Rate=57473kbps, Up Rate=20000kbps; SNR Margin Down=5.9dB, Up=6.3dB
05:00:23, 04 Jul. DSL Link Down: duration was 505 seconds
04:52:06, 04 Jul. DSL Link Up: Down Rate=57378kbps, Up Rate=20000kbps; SNR Margin Down=6.3dB, Up=6.6dB
18:47:27, 30 Jun. DSL Link Up: Down Rate=57410kbps, Up Rate=20000kbps; SNR Margin Down=6.3dB, Up=6.8dB
18:46:50, 30 Jun. DSL Link Down: duration was 62014 seconds
01:33:24, 30 Jun. DSL Link Up: Down Rate=57028kbps, Up Rate=20000kbps; SNR Margin Down=4.9dB, Up=5.1dB
01:32:47, 30 Jun. DSL Link Down: duration was 6247697 seconds
18:04:39, 18 Apr. DSL Link Up: Down Rate=53798kbps, Up Rate=20000kbps; SNR Margin Down=6.3dB, Up=6.7dB
18:04:03, 18 Apr. DSL Link Down: duration was 11040 seconds
15:00:11, 18 Apr. DSL Link Up: Down Rate=54134kbps, Up Rate=20000kbps; SNR Margin Down=6.1dB, Up=6.7dB
14:59:34, 18 Apr. DSL Link Down: duration was 75140 seconds
18:07:22, 17 Apr. DSL Link Up: Down Rate=54057kbps, Up Rate=20000kbps; SNR Margin Down=5.9dB, Up=6.3dB
18:06:09, 17 Apr. DSL Link Down: duration was 63704 seconds
00:24:33, 17 Apr. DSL Link Up: Down Rate=53979kbps, Up Rate=20000kbps; SNR Margin Down=5.8dB, Up=6.3dB
00:23:57, 17 Apr. DSL Link Down: duration was 195812 seconds
18:00:33, 14 Apr. DSL Link Up: Down Rate=39970kbps, Up Rate=9995kbps; SNR Margin Down=10.9dB, Up=15.8dB
17:59:56, 14 Apr. DSL Link Down: duration was 57371 seconds
02:03:53, 14 Apr. DSL Link Up: Down Rate=39970kbps, Up Rate=9995kbps; SNR Margin Down=10.6dB, Up=15.1dB
16:58:42, 13 Apr. DSL Link Up: Down Rate=39970kbps, Up Rate=9995kbps; SNR Margin Down=10.8dB, Up=15.8dB
16:58:05, 13 Apr. DSL Link Down: duration was 25541 seconds
09:52:32, 13 Apr. DSL Link Up: Down Rate=39970kbps, Up Rate=9995kbps; SNR Margin Down=10.9dB, Up=15.8dB
2 REPLIES 2
Mustrum
Fixes: 81
Re: Flaky connection after minor speed increase
Hardly worth worrying about, but at least your speeds are creeping up.
SilverE
Various devices including my phone don't reconnect after the line drops. So it is worth worrying about. I'd rather the speed didn't increase if it pushes the SNR to a point where it fails.
