Broadband down
Abdul5
Broadband down
From 6 pm my internet is down.Not able to contact customer support.Can you help me
8 REPLIES 8
Fixes: 382
Re: Broadband down
What lights are on the router?
Abdul5
Re: Broadband down
Orange
Fixes: 382
Re: Broadband down
Which router, and steady or flashing? Try rebooting the router.
Abdul5
Re: Broadband down
Plusnet hub Router
Flashing.Tried rebooting the router also
Fixes: 382
Re: Broadband down
Do you still have a phone service, or is this a SoGEA connection?
Abdul5
Re: Broadband down
Just broadband
Fixes: 382
Re: Broadband down
@Abdul5 OK, in that case, as support is closed until 0800 tomorrow, use this link to report a fault: https://www.plus.net/help/report-a-problem/
Abdul5
Re: Broadband down
Thank you
