Broadband down Shirwell
Dudgers
Had no broadband this morning.Tried all the usual,off-on-reset.Still not working
5 REPLIES 5
Fixes: 383
Re: Broadband down Shirwell
@Dudgers Try this instead.
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
What are your Hub/router lights doing?
Dudgers
Flashing purple
Bt Hub
Dudgers
Hi, it's the PlusNet Diagnostics bot here.
We have tested your service, and identified it is being affected by an incident in your local area.
Incident detected: 18-Jul-2023 09:28
Estimated fix date: 18-Jul-2023 15:26
Sorry for the inconvenience. We hope to have you back up and running as soon as possible
Fixes: 383
BT hub - flashing purple - sorry don't have clue. Is your phone line clear of noise?
EDIT:  OK, you have an identified problem.
willcutforth
Fixes: 113
@Dudgers glad it's found a fault. Let us know if there is still an issue after that time and I will have a look.
 Will Cutforth
