Broadband disconnects randomly and when phone is used
Fixes: 357
Re: Broadband disconnects randomly and when phone is used
OK - and you haven't had a response?
MartinConnolly
Yes, I have, it said I need to check the connection inside my home. Haven't had time to do that yet.
Fixes: 357
I would just remove and reseat your cables (phone/Hub, etc.) and see if that solves it, but years of experience tells me it won't - noise on the phone line is invariably caused by issues on the Openreach network, but it appears from my last fault before I moved to FTTP that they don't like to admit it.
MartinConnolly
Well, the issue with disconnects seems to have gone away. But my download speed is now down to about 35mbps instead of the 50+ I was getting recently.
Can anyone reset the line for me please?
Marsh
Fixes: 41
Hey @MartinConnolly,
I have just performed a DLM reset on your line. Please note that DLM reset requests can take up to 30 minutes to complete. After 30 minutes, I suggest rebooting your router and then do a hard-wired test. Please let me know if the speeds have increased.
Josh
MartinConnolly
Hi, yes I'm now getting 52mbps download. Thanks!
Marsh
Fixes: 41
Great to hear that it did manage to resolve the issue if you have any more issues, please update this thread Smiley
Josh
Something that has been niggling in the back of my mind...
If there is a copper fault between a street cabinet and a premises, would migrating to VOIP (going SOGEA) auto-magically clear that error/fault?
(N.B. I am throwing myself at the mercy of people who may know better)
Fixes: 357
@Anonymous I would highly doubt it, as migrating to VOIP merely means the voice component on the account is cancelled (disconnected), nothing physical is otherwise done to the line.
Thank you for confirming what I thought would be the case.
MartinConnolly
Hi @Marsh, my download speed has dropped again (from 50 to 33) after I had to unplug it a couple of times. Could you do another reset please? Thanks.
Marsh
Fixes: 41
Hey @MartinConnolly
I’m sorry to hear that your speeds have dropped to 33 Mbps. I can see that you’ve contacted us, and we have put something in place for the 28th. But when it comes to the DLM reset, I don’t believe it will make a significant difference, as the line will likely revert to its previous performance over time. Taking a look at the last 30 days, it is currently sitting at ~44 Mbps. I will proceed with the reset to help improve your speeds until the 28th.
After 30 minutes, I recommend rebooting your router and then running a wired speedtest.
Josh
MartinConnolly
Thanks @Marsh, it's back up to 57mbps now! Yes, the 28th is when I switch from Plusnet to EE so I can keep my home phone line Thanks for your help, I guess I'll be asking different people to sort things out for me in the future!
