Broadband connected but no internet
MrsC1985
My internet went live today (got the text and emails to say so). Came home, plugged router in, waited a while and all the lights went blue. Tried to connect but constantly just get the “login” page pop up which takes me to the hub manager which says it’s connected to broadband.
If I try to close this and go to any other page it says it cannot connect to the server!
I’m losing my mind! Can anyone help?
We have tried to restart too.
17 REPLIES 17
MrsC1985
Re: Broadband connected but no internet
Mustrum
Fixes: 81
You will need to log into the router and check the username, offs are its still setup@plusnet or something similar, and means your account has not yet been setup.
MrsC1985
Yes, it does have a setup@ thingy. Hopefully it’s sorted soon! Thank you
Mustrum
Fixes: 81
They normally say it can be done anytime up to midnight. However if a staff member such as @Gandalf who was online earlier sees this post, he may be able to get it activated for you.
Or if you fancy sitting on the phone for a while then support should be able to get you sorted.
MrsC1985
I hope so! Please Gandalf!
I rang but it was 30 minutes wait Sad
As long as I know what’s happening I’m ok!
Fixes: 1,652
Your orders look to have completed this morning and your account activated too.
It looks like your router wasn't auto-configured to your account before it was shipped from the warehouse. Can you try setting up your router manually by following the below steps?
1. Open an internet browser and type http://192.168.1.254 into the address bar
2. Press the 'Enter' or 'Return' key
3. Click on 'Advanced Settings'
4. Enter the admin password, which is on the back of the router
5. Click on 'OK'
6. Click on 'Continue to Advanced Settings'
7. Click on 'Broadband'
8. Click on 'Disconnect' if necessary
9. Enter your broadband username, which is in the format of yourusername@plusdsl.net
10. Enter your broadband password, which is your account password
11. Click on 'Connect'
MrsC1985
Thank you!!
Fixes: 1,652
No problems. Smiley
I take it that worked?
MrsC1985
It did, thank you very much Gandalf Smiley
Fixes: 1,652
Awesomeness. Smiley
jagg4960
Hi Gandalf I am a newbie plusnet user as of today but I have tried inputting the ip address you mentioned in both chrome and IE but page fails to load on both so Ive added it as a safe page on IE and am using my mobile to hotspot to my laptop so all should be fine. My router is new today and probably needs the router manually setting up any idea?
Currently a 20 min wait time to support.
Thanks David
jagg4960
its ok all sorted now thanks for info Gandalf
EmilyD
Aspiring Hero
Fixes: 117
Hi @jagg4960,
I'm pleased to hear that this is sorted for you now. Please let us know if there's anything else that you'd like to discuss.
 Emily D
claudiuantonio
Hi Gandalf,
I have the same problem, I set up the router, but I don't have internet access.
I changed the username from setup@plusdsl.net to my username and password, but nothing happens, it doesn't connect anymore and the light on the router is orange and the red b is on.
What can I do to fix it?
Thank you,
Antonio
