Broadband Speed Issues - 03/10/09
- Re: Broadband Speed Issues - 03/10/09
- « Previous
- Next »
24-11-2009 11:19 AM
I have Draytek 2800 router, will have a look at the Command-line interface (CLI) if it has a command from is stats page. I know that Cisco routes will tell with CLI.
I may have been put on a Noise Pofile, but my Uncorrected Blocks are reporting '2' and thats after 43 hours of up time on the WAN, My Uncorrected Blocks have never went above to '2' the only time I had lots of Uncorrected Blocks was on that Sunday morning, when I had no internet connection.
24-11-2009 11:21 AM
> adsl status
Look for DS Path Mode and US Path Mode
If interleave is on, it says "Interleave"
24-11-2009 12:05 PM
Many thanks for the router command. Here what it reported see below:
> adsl status
--------------------------- ATU-R Info (annex A) ----------------------------
Running Mode : G.DMT State : SHOWTIME
DS Actual Rate : 7616000 bps US Actual Rate : 448000 bps
DS maximum Rate : 7616000 bps US maximum Rate : 448000 bps
DS Path Mode : Interleave US Path Mode : Interleave
NE Current Attenuation : 15.5 dB Cur SNR Margin : 11.5 dB
DS actual PSDM(C) : 00000000 US actual PSDM(R) : 00000000
ADSL Firmware Version : E.38.2.23
-------------------------------- ATU-C Info ---------------------------------
Far Current Attenuation : 9.0 dB Far SNR Margin : 26.0 dB
CO ITU Version[0] : 00000000 CO ITU Version[1] : 00000000
DSLAM CHIPSET VENDOR : < Unknown >
INTL, DSTREAM bytes/depth= 0, symbols/codewords = 0, latency= 0*0.25ms.
, USTREAM bytes/depth= 0, symbols/codewords = 0, latency= 0*0.25ms.
CODE, DSTREAM fast parity bytes= 0, fast codeword= 0.
DSTREAM intl parity bytes= 0, intl codeword= 0.
CODE, USTREAM fast parity bytes= 0, fast codeword= 0.
USTREAM intl parity bytes= 0, intl codeword= 0.
Setting>>
FDQ : Enable, TCM : Enable, EC : Disable, Framing Mode : 3.
Running>>
FDQ : Off, TCM : Off, EC : Off.
DS : Framing Mode 3, US : Framing Mode 3.
ADI ADSL Firmware Version: E.38.2.23
So it looks like that Interleave is in fact "ON" and another thing looking at the "Far Current Attenuation" and "Far SNR Margin" they look OK as well, if I am reading it correctly, this is from the exechange?
24-11-2009 1:54 PM
Can I thank the following forum members jelv, paulh for their inputs with reference to my line sync problem, and also any of the Plusnet staff also.
24-11-2009 3:53 PM
You are currently connected to the "City Lifeline, Juniper 11" gateway. This gateway is sometimes known as pcl-ag04.
So, after a restart of the modem/router...
You are currently connected to the "Telehouse North, Juniper 2" gateway. This gateway is sometimes known as ptn-ag2.
Much better speeds! Presumably, the pcl-ag04 gateway still has problems then?
24-11-2009 4:10 PM
24-11-2009 6:38 PM
24-11-2009 6:54 PM
The cause of the problem has been identified, and Plusnet have released several Service Statuses detailing work that they have carried out, and will be carrying out.
I have unstickied this topic, as I don't believe that any more assistance is required in identifying the root cause.
However, if you are still having speed problems, please check the SS posts and then post in this forum for further assistance if required
Cheers
B.
24-11-2009 7:38 PM
Quote from: Barry Moderators Note
Cheers
B.
I don't see any updates to any SS's. Please can you point them out to us so we can find out when our problems will be fixed. Meanwhile, please re-sticky this because it's a little premature to be declaring everything is ok.
24-11-2009 7:44 PM
The purpose of his creating the thread and making it sticky was to get an evidence base from the user community to help PN diagnose the problem. In that it seems to have served it's purpose.
Not every post in this thread (not by a long chalk) now reflects an instance of the underlying problem.
(I wonder whether there is value in leaving it unlocked, or whether it might be better for people with speed problems to create separate threads now. Just a thought really. )
24-11-2009 8:12 PM
I'd suggest Barry should have gone further and locked this topic.
Certainly the mods should be splitting off posts that are not related to Barry's post that started this topic. A reminder:
Quote from: Barry There have been many reports of *severe* speed problems during peak times across packages and gateways recently. I would like to collate some information on them in the hope that Plusnet will be able to use this information to investigate common threads.
So, if you are having problems with peak-time speeds, can I ask you to read the following, and submit a reply answering as many of the questions as possible.
<snip>
Please include any other information that you think may be pertinent. Please keep it brief and to the point. If we can collate together as much information as possible then it should assist Plusnet in identifying a common cause and resolving the issue once and for all.
I have included a template post below, which you can quote from and then fill in.
Please note that any posts that are not in this format are likely to be split off, or removed without warning
B.
Quote from: Barry 1. Your product type
2. Your current usage from the VMBU
3. Your IP Profile, as reported by Plusnet
4. Information from the BT Speedtester
5. A Speedtest from an external testing site.
6. Your gateway
7. Your exchange status
8. Any other information
24-11-2009 8:16 PM
As suggested, thread is now locked.
if you have a speed problem, please start a new thread so that your individual issue can be tracked accordingly.
B.
03-12-2009 3:55 PM
Quote from: MacOS10 Thanks, bob, for the comprehensive reply. Yes, I thought changing products was a bit extreme - at least until things are fixed and the network balances out again. I hope the switch to 21CN helps too. Is there any way to fast track this or am I in the hands of the gods (BT) with that?
The order was originally due to complete 17th December. I've asked for it to be cancelled and brought forward to around the 10th.
- « Previous
- Next »
