Broadband Dropouts
- Re: Broadband Dropouts
- « Previous
- 1
- 2
- Next »
05-07-2013 6:27 PM
Yup, lots of errors!
I suggest you ask PN to turn on interleaving and see how that goes for a week or two.
If that doesn't fix it then an engineer would be the natural next step.
Message 16 of 23
(255 Views)
05-07-2013 6:43 PM
Don't forgot to "rm /tmp/debug" after enabling telnet, since you appear to be using a router like mine, otherwise you might end up with a ppp log filling up all the router's memory.
Message 17 of 23
(255 Views)
14-07-2013 11:23 AM
The interleaving has been turned on, however the upload has been capped
Message 18 of 23
(255 Views)
14-07-2013 11:58 AM
What firmware version do you have on your DG834G?
Message 19 of 23
(255 Views)
14-07-2013 2:44 PM
V4.01.28
Message 20 of 23
(255 Views)
14-07-2013 4:19 PM
I would have thought you would benefit from the newer adsl driver in later firmware versions, the last is version 4.01.40
See http://forum.kitz.co.uk/index.php/topic,1759.0.html
Message 21 of 23
(255 Views)
15-07-2013 12:51 PM
Thank you :D, updated my firmware on the router perfectly fine.
Could a plusnet staff please uncapped my upload?
Message 22 of 23
(255 Views)
15-07-2013 3:49 PM
Glad to see that's sorted for you, I've placed a modify order that will uncap your upload speed, this will complete tomorrow.
Message 23 of 23
(255 Views)
- « Previous
- 1
- 2
- Next »
