Blue light on router but no connection
Legend
Fixes: 255
Re: Blue light on router but no connection
Shouldn't do, but if it does, we can reset it - again.
lizzief25
No. that didn’t work either - still got orange horizontal light on the hub and red b
Legend
Fixes: 255
OK. Now we have a bit of a problem. I assume you are replying via a phone or tablet on 3/4G? which makes getting information off the router a bit difficult.
lizzief25
Yes correct. Have tried calling again but can’t get through, system busy has been message all day.
lizzief25
Appreciate your help so far!
Legend
Fixes: 255
Don't take this the wrong way - but how tech-savvy are you? Is it possible to take a picture of the 'Troubleshooter' tab on your computer/laptop and upload it to here?
lizzief25
Is that in settings?
Legend
Fixes: 255
I'm not familiar with the Hub, as I don't use it, but this picture should give you an idea of where to look. Note, this from the Hub1 (Fibre) router, but so far as I understand it the Hub0 (ADSL) is similar.Hub1.PNG
You need the right-hand tab.
Sorry for the delay, haven't got all my useful stuff transferred to my new laptop yet.😉
lizzief25
I managed to get through on the phone at last. It was showing an incorrect password for some reason which they have now reset. No idea how that happened as I don’t recall changing the password. Thank you for your help guys - you are really kind!
Fixes: 1,483
So you're back online?
Good news if so Smiley
Legend
Fixes: 255
I echo @dvorak s' reply above, but don't hesitate to come back if you need to - we're quite a helpful bunch on here.😀
lizzief25
Yes! Thanks again.
