Block device on Hub One router
perthiaur
Hello,
Is there a way to block certain devices form connecting to wifi on the Hub One router?
If so, is there a guide available?
Thanks.
3 REPLIES 3
MrSilver
Fixes: 9
Re: Block device on Hub One router
I dont know of a way to actually block a device, but do you know the mac address of the device? If so you could add them into the access controls list and restrict their time to nothing.
access-control-72946-large
Anoush
Aspiring Hero
Fixes: 139
Hello
I believe the Plusnet Access Control would probably be what you're looking for.
It'll allow you to set times that certain devices can access the web. In theory, you should be able to block those devices all times of the day.
I don't believe there's a guide, however, if you go to http://192.168.1.254 then click on Settings, and select Plusnet Access Control from the menu you'll be able to add the devices/times there.
I hope this helps
-Edit-
I see @MrSilver beat me to it Smiley
This is my personal Community Forum account to help out around these parts while I'm at home. If I'm posting from the 1st March 2020, this means I'm off-duty with no access to internal systems.
perthiaur
Great, managed to sort it out with your help.
Thank you very much!!!
