Bit torrenting and port addresses
- Re: Bit torrenting and port addresses
16-07-2007 12:22 PM
16-07-2007 12:24 PM
I've had a situation where uTorrent simply flooded my router, and it basically just started blocking access. A quick reboot of the router cleared all the port maps and made it function correctly again
B.
16-07-2007 1:27 PM
16-07-2007 6:10 PM
Plusnet Technology
16-07-2007 9:03 PM
17-07-2007 4:51 PM
IF your router supports UPNP leave UPNP on in utorrent.. saves the headache 🙂
31-07-2007 8:05 PM
01-08-2007 9:42 AM
01-08-2007 8:12 PM
the router settings. if using this in a wirless network then the ip your trying to use will be diffrent unless your pc is on 24/7
try setting your pc to 1 unique ip address and then open the port for that ip address.
let me know if that sorts it out?
02-08-2007 12:51 PM
