Banded?
redsox9
Fixes: 4
Banded?
@willcutforth
I reported a fault to BT on Oct 23 because of broadband connection drop-outs and noise on the quiet line test. An OpenReach engineer came two days later and said three other houses on my street had reported a similar problem. He tested my interior connections and left. BT texted two hours later that the fault had been fixed. My broadband has been stable for the last three weeks. I presume the training period has ended but the download speed is way below what I was getting before the fault. Here are the stats before the problem:
ADSL Link               Downstream     Upstream
Connection Speed  20246 kbps       1087 kbps
Line Attenuation      22 db                 4 db
Noise Margin           3 db                   6 db
The latest stats from my Netgear router after a reboot and the BT Performance Test are attached. Can you or any of your mates help?
4 REPLIES 4
Fixes: 585
Re: Banded?
@redsox9 your downstream SNR is way too high, you need a DLM reset after the fault being fixed.
You say you reported the fault to BT , so Im guessing that your line rental is with BT and your BB with Plusnet. That means the fault was treated as a voice fault and so the Openreach engineer wouldnt have been able to request a DLM reset via BT.
willcutforth
Fixes: 113
Re: Banded?
@redsox9  Like the Flash I have been quick on this one as well for you. The reset has been popped through. Technically I'm supposed to follow through the trouble-shooter but I am a troublemaker who can't be tamed.
Let us know how it goes.
 Will Cutforth
redsox9
Fixes: 4
Re: Banded?
Thanks for the reset, Will. That was quick. My stats look back to normal. See attached.
willcutforth
Fixes: 113
Re: Banded?
Awesome, glad to hear it! Let me know if you need me to do anything else Smiley
 Will Cutforth
