Back to square one
- Re: Back to square one
- « Previous
- 1
- 2
- Next »
15-11-2010 11:07 AM
Hi Joanne, at last someone with an idea, why hasn't this been thought of before I wonder? Hunches are often the best way of solving a problem. As using the computer cabled up is not really an option how come Plusnet can't just try changing the channel and seeing if that solves the problem? The service couldn't be any worse so isn't it worth a try. It does seem across the board that anything to do with computers is always the problem of the customer and not the seller, if I ran my business that way I would have no customers left and wouldn't need a computer, perhaps that's the best way to go!! would solve the problem. Anyway thankyou Joanne for taking an interest, pity it has to be through a forum. Am off to pack up and send back the test router now, lovely sunny day here.
Message 16 of 22
(470 Views)
15-11-2010 11:22 AM
Hi janedunkley,
I know it may not be practical for you to work wired to your computer but if you could do this so we can definitely rule it out then we can work on the wireless. There's no point messing around with the channels until we definitely know that's the issue or we could be heading down the wrong route and it could take us longer to get to the root of the problem. If you can confirm that it's ok with the wire then I don't mind ringing you today or this evening to go through the channel set up for you.
Jojo
Jojo
Message 17 of 22
(470 Views)
15-11-2010 3:35 PM
If you are having to stand in the window it sounds like you might not be connecting to your own router!
Message 18 of 22
(470 Views)
15-11-2010 3:54 PM
Or could your Macbook just be too far from your router? Most wireless routers will cover a typical suburban house if positioned centrally but if they are in one corner of the house then the wireless signal at the opposite corner of the house might not be strong enough to give a reliable connection. If you have an old house with thick stone walls, that will tend to block the wireless signal. Modern metal-backed cavity wall insulation can also cause all sorts of wireless problems.
Message 19 of 22
(470 Views)
15-11-2010 6:52 PM
See Reply #3 in this thread http://community.plus.net/forum/index.php/topic,90655.0.html
Message 20 of 22
(470 Views)
16-11-2010 9:11 AM
Internet working fine this morning, can't remember the last time it was so easy to reply to mails. No doubt this will be the case now for 3 days so I am told to do the whole process of testing again when it starts over. Hmmmm, watch this space all you kind people who are trying so hard to help.
Message 21 of 22
(470 Views)
16-11-2010 4:04 PM
Jane,
The post I linked to earlier would suggest that the issue you are seeing is a Wireless incompatibility between your Macbook and your Router. Whereas these are NOT faults with either piece of kit, there are two fixes suggested for this which you should apply to circumvent the problem you are seeing.
1) Change the SSID of the Router to a simple six letter (or less) name. This is very easy to do and I am sure that Joanne will be willing to call you and prompt you through the procedure.
2) Change the Wireless encryption from WPA - AES to WPA - TKIP only. Again, this is very easy to do and I am sure that Joanne will be willing to call you and prompt you through the procedure.
I realise that your eyes will have glased over at the mention of the three and four letter abbreviations but stick with at and it can be fixed. It really is so simple that I think I could teach my Collie to do it.
R
R
Message 22 of 22
(470 Views)
- « Previous
- 1
- 2
- Next »
