BT to Plusnet Transfer - Advice needed please
Ed_B
Hi Everyone
I have run through the various posts and can't find anything recent so, at the risk of missing a similar post, I will try to see if more current advice can be given.
We are currently nearing the end of a two-year full fibre and landline contract with BT. At the moment, it costs us £83 / month for a 900 MBPS connection. We have 5 BT Black discs which deliver a great wireless signal around the house.
Our contract expires in January 2025 and, in the interim, I thought that I would have  a look at any suitable (and hopefully cheaper) solutions.
I suspect that we will have to hand back the router and 2 of our 5 BT black discs when the contract finishes.
What I am thinking about is moving to a 900 MBPS Plusnet service and what I would really like to do it to retain our BT Smart Hub 2 and our 3 BT Black discs, buy a further 2 black discs on eBay and configure the BT Smart Hub 2 to work with our Plusnet account.
So, this morning, I tried to access our BT router using the address http://192.168.1.254/
I clicked on 'Advanced Settings' but then couldn't find a menu where my BT connection credentials (username and password) were shown or where I could change them.
So, I am now thinking that I may not be able to re-use my BT Smart Hub 2 if I move to Plusnet but thought that, before I make any decisions on which way to go, I would check with our community to see if anyone else has tried this route and, if so, how did they get on ?
I hope this all makes sense and, again, apologies if I have missed a similar posting. If that is the case, could someone refer me on to the link please ?
Kind regards
Ed
28 REPLIES 28
Fixes: 374
Re: BT to Plusnet Transfer - Advice needed please
@Ed_B BT will require the return of their Hub when you move, and whatever else was supplied as part of the contract.
Have you looked at any other ISP's? Bare in mind that if you move to PN, you will have to arrange your own VoIP service - Plusnet are the Broadband only 'cheap' arm of BT Consumer Group, and do not have a VoIP service.
I don't, off the top of my head, know what Zen charge for their 900Mb/s service, but they do have an integrated VoIP solution - the call package, if you need a landline is a flat £7../month for 1000 minutes.
jgb
Champion
Fixes: 22
@Ed_B
Zen charge £55/ month for 900 Bb/s (with a £15 set up fee). That price is with Openreach. If they can supply you via an Altnet (e.g City Fibre) it will be about £6 less for the broadband.. Their Digital Voice is £6 /month for 1000 minutes.
You just plug your existing phone into their router and so there is no configuration to do.
Fixes: 374
Cheers for the prices and correction, @jgb 👍
jgb
Champion
Fixes: 22
@jab1 @Ed_B  I should also have said it is an 18 month contract with no in contract price increases.
Fixes: 374
I should have guessed it was an 18 month contract - mine is, and I'm well aware there are no in-contract price rises. It will be interesting to see what happens next August when I'm due to renew.
Ed_B
Hi John
Many thanks for getting back to me. I'm really grateful.
Yes, I guessed that BT would want the router back so I have purchased a new / in box BT router which I plan to send back to BT when they ask for the return of their router. That would leave me with my current BT router and 3 of the BT black discs (I have bought these over the last 2 years).
Yes, the landline has been a bit of an issue. It wasn't until we sat back and said 'why do we need a landline when we have our mobiles ?' that we realised that the real reason that we thought we needed it was because we have always had one ! Old school I'm afraid !! So, moving to Plusnet and losing the landline won't be too much of an issue for us.
I must admit that I haven't looked at any other ISP purely because I think the BT wireless coverage is so good. Our house has pretty thick walls and the BT Wireless solution seems to cope with them really well.
John, thank you for you great reply and also thank you for sparing time on a Sunday to give me the benefit of your advice.
I'm still not sure which way to go but am really hoping that I can use our existing BT Router and the black discs and just move them to Plusnet. I have calculated that making the move to Plusnet would halve our current BT bill and, these days, every penny counts.
All the best
Ed
mystreet1
Seasoned Pro
Fixes: 7
If you keep all the BT equipment you will probably have to pay a 'unreturned equipment ' cost. See how much that is. Think that PN charge is £50 for the PN hub 2.
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
Ed_B
Hi JGB
Many thanks for your great replies.
I'm thinking that I will drop the landline. On our existing BT contract, if we use the landline, I believe we are charged 22p per minute ! We have really thought of the landline as a 'safety net' that would enable incoming calls rather than a service that we would use to make external calls.
I'm still hoping to continue to use the BT Router with Plusnet although, as I mentioned, I have had a good look through this site and, although others seem to have managed it, their responses are over a year old and it may be that the firmware in my BT Router just doesn't allow me to edit the username, password and connection url. I did notice, when I purchased our spare BT Router that a number of these routers were 'hard connected' to BT. And it maybe that what I am hoping to do (i.e. use the BT hardware on the Plusnet network) just isn't possible.
I'll keep looking for a solution and, if I manage to get one that works, I will carefully document it and post it here to help others.
All the best and with grateful thansk
Ed
Fixes: 374
@Ed_B wrote:
Hi John
All the best
Ed
I can see where you are coming from with regards to the BT Hub, and your 'cost reduction' requirements, and I admit to not knowing much about BT/PN kit these days - I left 2.1/2 years ago when I was still on ADSL with the TG582N router - not because I was dissatisfied with PN, but because I didn't like the way I could see the brand going.
I don't know how other suppliers (other than Zen (thanks, @jgb ) compare, but they (Z) do have a 'whole home' solution, which I understand, is very well regarded - I don't need it, so can't comment personally.
Ed_B
Hi John
Many thanks again (and especially as it is a Sunday !).
I'm definitely going to follow your recommendation and take a look at Zen. Looking at our real needs, I suspect the key requirement is having a  good strong wireless system around the house to enable us to run the various wireless components that we have added over the last 2 years. (we use a ring camera system which works really well across our current BT wireless system).
I will post an update once I have managed to resolve the question of where we go next.
All the best (and with grateful thanks again)
Ed
Fixes: 374
No problem, @Ed_B  - although it is getting round to 'log off' time now.😀
Ed_B
Ji John
Absolutely, I'm just grateful for your support.
Also, I am not sure how I missed it initially but I have just found a link that sheds more light on using a BT SmartHub 2 on the Plusnet Network.
Here's the link..
https://community.plus.net/t5/My-Router/Using-A-BT-Smarthub-An-Update/td-p/1795292
I'm not sure if I will be able to use the black BT WiFi mesh discs but I'm going to call Plusnet in the morning and ask them. Hopefully, they will be able to advise me one way or the other.
All the best
Ed
Fixes: 569
@Ed_B customer services will have no idea whether the discs will work ,why would they know about BT equipment.
have a look at this thread though https://community.plus.net/t5/Full-Fibre/Compatibility-of-BT-Black-Disc-Range-Extenders-with-Plusnet...
markhawkin
Aspiring Champion
Fixes: 20
@Ed_B
I suggest setting up your "new in box" router on your BT account.
That will require account credentials (as your existing router is "tied" to your account).
I guess you will also need to send back the "right" device to get your return registered.
If the "new" router can be made to work on BT (it may require credentials to be entered with the device "offline") the process will show you how to enter the Plusnet credentials as well.
