BT Wholesale Broadband Performance Test - 0.08MB download result
jono1001
I've been having problems around 9pm onwards for the last couple of nights with download speeds/connectvity.
Tonight I ran the BT Wholesale speed test and got the result of 0.08MB download.
I've tried using the fault check but get a "Troubleshooter Error: try again later"
Any suggestions as to what I can do?
Router: BT Home Hub 4
10 REPLIES 10
jono1001
Re: BT Wholesale Broadband Performance Test - 0.08MB download result
Replaced microfilter - no difference
Replaced Router with plusnet router 2704N - no difference
https://www.speedtest.net/ - gives a "Latency test error"
jono1001
And pretty much back to normal again this morning ... Surely not a contention issue?
SammyM
Fixes: 84
Hello @jono1001,
I am sorry to hear this and welcome to the forums. I have checked with our supplier and they have advised that there is no indication of capacity issues at the exchange and our tests are not highlighting any issues.
There were 3 drops last night after 21:00, can you advise if this was you resetting/rebooting  the router? The speed tests that you have attached were this via a wired or wireless connection?
 Sammy M - Sheffield Team
jono1001
3 drops are likely to be reboot, change from BT to PlusNet hub and change back to BT hub.
All tests via Wi-Fi as I have no wired connection.
Not likely a WiFi issue as sat close to router (on master socket) and the morning scenario is the same.
Anything I can run to check issues when it occurs ~9pm ...?
MasterOfReality
Fixes: 57
Hi @jono1001
Thanks for getting back in touch with us.
As @SammyM testing is not identifying any issues - therefore we really would need wired connection tests conducted at your end. WiFi is merely an optional alternate gateway to access the internet - a wired LAN (Ethernet) connection is always the primary connection method, and is the only one which can be guaranteed on both speed and stability.
There are a large number of potential reasons for slow speeds and sometimes these are difficult to track down.
If these issues do not appear on Wired tests, them it's likely the problem lies between your router and your devices which we don't have visibility of.
Unfortunately due to the way WiFi works there are a lot of environmental factors which can affect the wireless signal.
Have you tried changing the wireless channels? If not, then please follow the steps here
Kind Regards,
MoR
jono1001
Hi and
Thanks for your support and suggestions.
What wired tests would I need to run?
I can resurrect a Linux box but would need to know that the effort would be worthwhile, i.e. not requiring Windows platform.
I'm assuming the change of wireless router would have eliminated some WiFi issues, but understand there are other potential factors.
MasterOfReality
Fixes: 57
@jono1001 - Wired speed tests whilst connected to your Test Socket would be the next best step.
A guide on how to locate your test socket can be found here
Thanks,
MoR
jono1001
Thanks I'll see if performance drops again tonight and then run the same BT wholesale speed tests again.
jono1001
No issues seen tonight. Will keep an eye for the rest of the week and update.
Download Speed (Mbps): 10.56
Upload Speed (Mbps) : 0.61
Ping Latency (ms): 1394
MasterOfReality
Fixes: 57
Thanks for letting us know, @jono1001
Give us a shout if we can do anything for you.
Kind Regards,
MoR
