BT Speedtester
dave
Fixes: 6
BT Speedtester
Has anyone tried the BT speedtest on 21CN yet?
http://www.speedtester.bt.com
Just trying on my test line in the office and at home which were both installed this week and getting speeds below 100kbps (other speedtests are fine) and had a customer saying the same so wondering if there's any pattern.
Tried Safar on the test line on a Mac and IE on my home line on Windows 2K. Would be useful to gather feedback on what works or doesn't work as the case may be say that we can raise it as an issue (or identify what combination of browser/OS works) so if a few people could give it a go would be appreciated.
Dave Tomlinson
Plusnet Technology
19 REPLIES 19
scootie
Re: BT Speedtester
bt tester even on my adsl line gave very low results very often double and three fig results.
i just tried to do the bt speed tester now i have bein switched to adsl2 but i keep getting system busy tried  a few times but the same.
came here to ask if this norm on the first day of wbc upgrade
zubel
Re: BT Speedtester
It worked fine for me earlier, although the speed was constrained by my PN profile still being 7150.
B.
scootie
Re: BT Speedtester
still getting test error (busy) at 23.30
spraxyt
Resting Legend
Fixes: 75
Re: BT Speedtester
It's just worked for me (on the old network) from NW England, but took longer than usual to get through the phone number check.
David
James
Re: BT Speedtester
I can't use it for obvious reasons.
It;s been giving rubbish results on ADSL and ADSL2+ for months/years
scootie
Re: BT Speedtester
just managed to get a bt speed test done. the results cam back as what i would suspect why i was downloading shameless off 4OD
1500kbps ish on a 3000kbps profile.
if my line keeps its current adsl2 sync rate going till tomoro daylight i can smell a 3500kbps profile coming Cheesy
pierre_pierre
Re: BT Speedtester
not on ADSL:2 I normally for the last few months have had stupid throughput results, just done this pair
Test1 comprises of Best Effort Test:  -provides background information.
    Your DSL connection rate: 8128 kbps(DOWN-STREAM),  448 kbps(UP-STREAM)
    IP profile for your line is - 7150 kbps
    Actual IP throughput achieved during the test was - 6280 kbps
my Broadband Speed
Today 07:00  6634 kbps (829kB/s)  381 kbps (47.6kB/s)
dave
Fixes: 6
Re: BT Speedtester
Ta, be interested to see if anyone else on 21CN gets the ~100kbps speeds myself and the other customer were seeing.
Dave Tomlinson
Plusnet Technology
scootie
Re: BT Speedtester
Grin Grin Grin nothing else running on line at same time.
time of test same as post time.
    Your DSL connection rate: 3499 kbps(DOWN-STREAM),  871 kbps(UP-STREAM)
    IP profile for your line is - 3000 kbps
    Actual IP throughput achieved during the test was - 83 kbps
Today 19:16 2722 kbps (340kB/s) 742 kbps (92.8kB/s)
spraxyt
Resting Legend
Fixes: 75
Re: BT Speedtester
This is quoted from a Speed Thread post this evening (went live 04/03/2009):
Quote from: adamski69
Your DSL connection rate: 13636 kbps(DOWN-STREAM),  1092 kbps(UP-STREAM)
    IP profile for your line is - 8000 kbps
    Actual IP throughput achieved during the test was - 126 kbps
David
dave
Fixes: 6
Re: BT Speedtester
Cheers, those are more like what I'm seeing on the 2 lines I tried it on. We'll get that one fed back to BT after the bank holiday.
Dave Tomlinson
Plusnet Technology
zubel
Re: BT Speedtester
    Your DSL connection rate: 11269 kbps(DOWN-STREAM),  888 kbps(UP-STREAM)
    IP profile for your line is - 9000 kbps
    Actual IP throughput achieved during the test was - 57 kbps
That's on my first 21CN enabled line.
B.
penfold
Fixes: 5
Re: BT Speedtester
Yep same here for me too.  TBH, BT should be ashamed of themselves. Its got to be the most unreliable speedtester there is, and BT say they need it to raise Speedtest faults.  I say get the damn thing fixed or scrap it for something better,
VileReynard
Fixes: 20
Re: BT Speedtester
Had a BT engineer round.
One of the first things he said was "you know those BT speedtester results aren't reliable, don't you?" Smiley
