BT Home Hub 5
- BT Home Hub 5
Re: BT Home Hub 5
06-11-2013 9:08 PM
I've received an confirmation email saying my BT hub 5 has been dispatched or despatched (I don't know what the difference is between the 2 words) and should be with me on Friday 8th November.
I can't wait, anyone used it on FTTC? What is it like?
Re: BT Home Hub 5
07-11-2013 5:25 AM
Re: BT Home Hub 5
07-11-2013 6:27 AM
Re: BT Home Hub 5
07-11-2013 5:06 PM
Re: BT Home Hub 5
07-11-2013 7:05 PM
I change the 5ghz network name I.e BTHub5-WS68_5GHz
Or change wifi channel
Use inSSider to find a suitable channel
Re: BT Home Hub 5
07-11-2013 7:27 PM
Re: BT Home Hub 5
07-11-2013 8:28 PM
Re: BT Home Hub 5
07-11-2013 8:33 PM
Re: BT Home Hub 5
07-11-2013 10:39 PM
However 7mb is radically low.
This should be investigated by PN
Try doing a bt wholesale test with Ethernet cable
Sorry for slang, typing from iphone
Re: BT Home Hub 5
08-11-2013 7:15 AM
Quote from: NorthEasterner It's probably due to the fact when u swapped the router the DLM thought ur line was unstable so put it to a lower speed.
Absolute trash. DLM would not slow the connection down after one disconnection.
Re: BT Home Hub 5
08-11-2013 7:23 AM
Re: BT Home Hub 5
08-11-2013 4:35 PM
Quote from: Susie
If you have a problem then please don't take it in an aggressive way.
One disconnect can influence on the equipment used and DLM's can vary on exchange.
My DLM is very sensitive. I turned my router off and I was put on 10mb then increased over a few days
Re: BT Home Hub 5
08-11-2013 4:42 PM
Redelivery to post office made on Monday, well worth £1.50 for collection as my RM depot is 3 1/2 miles away. PO is 2 mins away. Makes sense
Re: BT Home Hub 5
11-11-2013 8:49 PM
Looking quite good.
I bought a new RJ11 cable on way back from work from PC World for around 3 quid (good quality)
I connected the RJ11 cable to Hub 5 but stupidly forgot to connect to master socket.
I was trying to figure out for half an hour why it wasn't connecting. I referred to the instruction booklet, it said, "Make sure all cables are connected" This is when I realized.
What am I like!!! hahaha
Re: BT Home Hub 5
11-11-2013 11:55 PM
