BT Home Hub 5
- BT Home Hub 5
Re: BT Home Hub 5
12-11-2013 5:18 PM
But fluctuates on 2.4GHz
My line speed is 57Mbps. I connect all my devices to 5Ghz network and non 5GHz wifi enabled devices connect to 2.4GHz
Very happy. No charges on my BT account for the router apart from £6.95 postage charge.
Set up was easy. Waiting to be put on the fast path
Re: BT Home Hub 5
23-11-2013 11:33 PM
3. Firmware version: Software version 4.7.5.1.83.8.173.1.4 (Type A) Last updated Unknown
4. Board version: BT Hub 5A
5. VDSL uptime: 2 days, 08:57:31
6. Data rate: 17133 / 63076
7. Maximum data rate: 17331 / 74983
8. Noise margin: 6.0 / 7.1
9. Line attenuation: 0.0 / 17.8
10. Signal attenuation: 0.0 / 17.8
Re: BT Home Hub 5
24-11-2013 6:47 PM
Re: BT Home Hub 5
24-11-2013 7:22 PM
It will disable after a few days.
Jamie
Re: BT Home Hub 5
27-11-2013 11:06 PM
Has anybody managed to do this yet and if so how. Many thanks.
Re: BT Home Hub 5
27-11-2013 11:24 PM
enter admin password and enter the Broadband username: username@plusdsl.net
Broadband password: (your username password)
Re: BT Home Hub 5
27-11-2013 11:40 PM
Re: BT Home Hub 5
27-11-2013 11:57 PM
Re: BT Home Hub 5
28-11-2013 12:00 AM
Re: BT Home Hub 5
28-11-2013 12:47 AM
Re: BT Home Hub 5
28-11-2013 1:30 PM
The plusnet router has weak wifi signal so i am hoping this BT one will be much better. Will then have to update my laptop wifi card too to make most of it.
Re: BT Home Hub 5
28-11-2013 4:48 PM
jim:quote
Re: BT Home Hub 5
28-11-2013 5:05 PM
Current Stats From My HH5.
5. VDSL uptime: 7 days, 02:52:31
7. Maximum data rate: 17324 / 75274
8. Noise margin: 5.9 / 6.4
Re: BT Home Hub 5
28-11-2013 5:50 PM
http://community.plus.net/forum/index.php/topic,113872.0.html
This applies to to all hubs from 2 onwards on ADSL and 3 onwards if using FTTC
All hubs apart from 1 can be used on PN ADSL service
Re: BT Home Hub 5
28-11-2013 7:29 PM
