BB12 Area Broadband Dropouts
- BB12 Area Broadband Dropouts
21-08-2016 4:06 PM
I have noticed another customer with a very similar issue to mine in this forum. Thought i would post my issue as well.
Since Friday afternoon, we have been experiencing frequent dropouts which only last a few seconds to half a minute, which is more than enough to be kicked out of a game/freeze up Netflix etc.
I have done the usual, reboots etc. I know it's not a BT box or Router issue, as if they were to loose power, it takes minute to reestablish a connection rather than seconds. There is nothing on the fault/service tracker pertaining to my location, so this may well be something to look into.
Thanks.
Re: BB12 Area Broadband Dropouts
22-08-2016 6:30 PM
tests aren't showing either an obvious or a common cause for the issue you're seeing but we do see that the connection is dropping frequently.
Thanks for reporting the issue with us formally, a member of our faults team will be getting back to you soon.
Adam Walker Plusnet Help Team |
