BB+ ? is this now being throttled on usage
- Re: BB+ ? is this now being throttled on usage
29-09-2007 11:59 AM
Hi, what was wrong with thew old forums ! anyways i have always been on BB+ with the only limits being between 4pm and midnight yet now i can no longer get any faster than about 50k a second
am i being throttled during my off peak hours, due to my usage ? ? ?
29-09-2007 11:52:57 456
11-08-2007 06:59:00 3700.6
14-06-2007 15:39:41 3736.1
Message 1 of 4
(1,467 Views)
3 REPLIES 3
29-09-2007 12:14 PM
BB+ seems to get throttled, but not in any very clearly defined or consistent way, after you hit around 1.5GB peak usage (this was acknowledged by PN staff on the old forums during the February BB+ debacle)
If you're not over that number then the chances are there's a technical problem somewhere I guess?
paul
(also a BB+ user but with no speed problems)
paul
Message 2 of 4
(507 Views)
29-09-2007 1:27 PM
What gateway are you on? I've checked your account and no additional throttling should be in place on your line
I'm guessing you're victim to BT's bRAS profiling.
Headline Rate-Downstream Line Rate BIP Update Time Sync Rate Sync Timestamp
500 29/09/2007 06:48 576 29/09/2007 06:31
500 29/09/2007 06:47 4544 27/09/2007 21:04
4000 27/09/2007 21:16 4544 27/09/2007 21:04
4000 27/09/2007 21:06 5120 27/09/2007 06:49
4500 27/09/2007 07:18 5120 27/09/2007 06:49
Message 3 of 4
(507 Views)
29-09-2007 4:23 PM
Thx Bob
nice to know
though as for a gateway !
well i have just done another speed test and
29-09-2007 16:24:04 3510.9
back up to to what it should be, just hope it stays that way must just have been having an off period for a few hours
cheers petsyb
Quote your account and no additional throttling should be in place
nice to know
Quote You are currently connected to the "unknown" gateway.
cheers petsyb
Message 4 of 4
(507 Views)
