Azure file share port 445 blocked
seebee
Fixes: 9
Re: Azure file share port 445 blocked
@GavB I am on the same IP range as you mention in post #7 (51.9.x.y) and it works for me
Test-NetConnection -ComputerName "bpguksstorage.file.core.windows.net" -Port 445 -InformationLevel "Detailed"
ComputerName : bpguksstorage.file.core.windows.net
RemoteAddress : 51.141.129.72
RemotePort : 445
NameResolutionResults : 51.141.129.72
MatchingIPsecRules :
NetworkIsolationContext : Internet
IsAdmin : False
InterfaceAlias : WiFi
SourceAddress : 192.168.203.114
NetRoute (NextHop) : 192.168.203.1
TcpTestSucceeded : True
(my DNS is my Openwrt router, and it uses PlusNets SafeGuard DNS servers)
Fixes: 396
@Dan_the_Van  good idea! Whilst it might not 'prove' its an IP issue , it will certainly prove whether its a port issue.
@seebee useful information
GavB
@Dan_the_Van it connects to port 80:
RemotePort : 80
InterfaceAlias : Ethernet
SourceAddress : 192.168.1.123
GavB
@seebee thanks, that's good to know.  I wonder what is different for me then, the only thing I can think is the router?
Fixes: 396
@GavB  well i never, it is the router🙄
https://en.avm.de/service/knowledge-base/dok/FRITZ-Box-7590/835_Shared-files-and-printers-on-a-compu...
Looks like it can be fixed by disabling the NetBios filter though
https://serverfault.com/questions/1056711/why-would-blocking-netbios-packets-impact-smb3
Aspiring Hero
Fixes: 74
@GavB
does the router have a firewall event log and does it provide anything useful?
GavB
Woohoo!  Awesome, thank you!  I was looking at those settings earlier and I did wonder.
Thanks everyone for all the help Smiley
Fixes: 396
@GavB  you might want to let your IT support know about the issue with Fritzbox routers in case they have other users of them.
Although I suspect they will either not be interested or won't understand🙄
GavB
Thanks, yes I told them and they said "That's very interesting, We have seen a lot of internet suppliers blocking the port 445 But I will add this to the knowledge hub for future reference." which to me sounds like "I have no idea what that means" 😂
I've posted it to our group chat too and hopefully this forum thread will help others who are having similar issues.
The Fritz!Box was very expensive when I bought it but it has been pretty darn good on the whole.
Legend
Fixes: 255
They obviously haven't a clue - in your case, and I suspect others, it isn't the ISP blocking access, it it is your modem/router.
Champnet
Aspiring Hero
Fixes: 12
In fairness you won't find many, if any, 'home quality routers' in IT departments. Unless the routers are supplied by the Company for remote users then staff knowledge will be based on their own systems at home.
Legend
Fixes: 255
Fair enough, @Champnet , but I would have thought they could ask which modem/routers were being used, and as someone (can't remember who), on here has done, check the specs of said hardware?
