Are you satisfied with the Plusnet router tg582n ?
- Re: Are you satisfied with the Plusnet router tg58...
- « Previous
- Next »
Re: Are you satisfied with the Plusnet router tg582n ?
26-04-2013 9:35 PM
https://play.google.com/store/apps/details?id=com.farproc.wifi.analyzer&hl=en
26-04-2013 10:05 PM
26-04-2013 10:23 PM
well i have a tg582n upstairs and tbh i had to turn my living room ap tx UP to stop my stuff trying to connect to the tg582n upstairs.
Quote from: njay That's the one I use. It shows my nano router has a stronger signal than my 582n even when I'm standing next to the latter and 10m from the former lol.
I've had my share of problems with the tg582n, but signal came last on my list of stuff that caused me any bother.
At the moment i seem to have everything working as expected, now either it was down to me messing around with tweaks or plusnet did something that stopped my dns resolver type problems. Either way atm i'm happy with the plusnet router... omg did i just ssy that lol......
26-04-2013 10:43 PM
I would comment that the GUI is very restricted and the wireless range is very poor compared with others I've tried, but it connected and worked flawlessly straight out of the box so I'm pretty satisfied for a freebie!
27-04-2013 12:25 AM
27-04-2013 6:51 AM
27-04-2013 9:59 AM
Pros ..
-- worked straight out of the box without ANY configuration - easy for non-techy types (Probably the overwhelming majority)
-- Having switched from my trusty old DG834G, I'm surprised to find that the Wifi performance is quite a bit better both in speed (The 'N', I guess) and signal coverage. This seems to conflict with what others are saying here.
Cons
-- GUI is not intuitive, even for someone with years of experience in data networking
-- Getting port forwarding for an FTP server to work was, umm ... challenging!
-- Had to abandon the GUI and telnet in to configure OpenDNS. Can't believe that!
Overall, I'd say excellent value for £5.99
03-05-2013 1:10 PM
other than the wireless, it's fine.
but wireless coverage is an absolute must.
03-05-2013 1:17 PM
Why not use the 8960n as it can be reconfigured to have one of its LAN ports as a EWAN?
03-05-2013 1:51 PM
13-05-2013 11:38 PM
Was initially happy but after going to U/L definitely not.
The Wi-Fi performance is not good enough. It's now the weak link. None of the devices I've got will connect at more than 65Mbps even though all three are capable of more. Even messing around with CLI commands will not enable more than 144Mbps from the router. It's supposed to be able to support up to 300Mbps but no go for me. I'll admit I'm in a busy area for Wi-Fi but this, for me, just highlights the device's weaknesses.
Opened a support ticket but they weren't interested once I mentioned CLI. Is it faulty? Perhaps it's crippled. Either way it's not good enough to be used for a premium product, i.e. up to 80Mbps fibre.
On the plus side it does what it does reliably. I'm used to its UI from my previous O2 box so got my configuration needs done OK.
Andy
- « Previous
- Next »
