Are these stats normal? will i ever roam azeroth?
- Re: Are these stats normal? will i ever roam azero...
01-01-2011 11:53 PM
DSL Connection
Link Information
Uptime: 1 day, 22:32:15
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 8,128
Output Power (Up/Down) [dBm]: 12.0 / 19.5
Line Attenuation (Up/Down) [dB]: 15.0 / 28.0
SN Margin (Up/Down) [dB]: 23.0 / 8.0
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Framing (Local/Remote): 11 / 0
Loss of Signal (Local/Remote): 1 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 1 / 0
FEC Errors (Up/Down): 18 / 9,813
CRC Errors (Up/Down): 18 / 7
HEC Errors (Up/Down): 4 / 6
The reason i ask is because im a little bit addicted to playing WoW. I had an error on my line on the 29/12 which is now resolved, ie i have an internet connection, BUT when ever i do ping tests:
When ive logged into WoW i get around 5 mins of 125ms latency then i jumps to around 3000 and does not go back down.
Is there anything wrong at my end or what?
Thanks...
P
Link Information
Thanks...
P
Message 1 of 5
(895 Views)
4 REPLIES 4
Re: Are these stats normal? will i ever roam azeroth?
02-01-2011 12:15 AM
It looks OK, but your pingtest.net is to Dublin, so will introduce a bit of lag, however, you'd be better to do a command line ping. Assuming Windows, open a command prompt and type
As you can see, my pings aren't great, but as I'm not a gamer I don't really notice it...
ping www.plus.com- you'll get output similar to this (not using Windows on this PC)
ping www.plus.com
PING portal.plus.net (212.159.9.2) 56(84) bytes of data.
64 bytes from portal.plus.net (212.159.9.2): icmp_req=1 ttl=247 time=51.2 ms
64 bytes from portal.plus.net (212.159.9.2): icmp_req=2 ttl=247 time=62.0 ms
64 bytes from portal.plus.net (212.159.9.2): icmp_req=3 ttl=247 time=47.9 ms
64 bytes from portal.plus.net (212.159.9.2): icmp_req=4 ttl=247 time=52.3 ms
^C
--- portal.plus.net ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3004ms
rtt min/avg/max/mdev = 47.960/53.399/62.073/5.258 ms
Message 2 of 5
(519 Views)
02-01-2011 12:21 AM
Thanks for the reply
Done the ping.... results below
Pinging portal.plus.net [212.159.8.2] with 32 bytes of data:
Reply from 212.159.8.2: bytes=32 time=107ms TTL=249
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 212.159.8.2:
Packets: Sent = 4, Received = 1, Lost = 3 (75% loss),
Approximate round trip times in milli-seconds:
Minimum = 107ms, Maximum = 107ms, Average = 107ms
Request timed out.
Request timed out.
Request timed out.
Message 3 of 5
(519 Views)
02-01-2011 12:26 AM
Message 4 of 5
(519 Views)
02-01-2011 12:30 AM
Message 5 of 5
(519 Views)
