Are microfilters still required without telephony?
glocal
I recently renewed my FTTC contract and lost telephony. All working well but is a microfilter still necessary? The router cable plug won't fit directly into the BT point obviously, but there may be a suitable cable for that. My thinking is that I could simplify the connection, reducing clutter and possible failure points, and improving speed at the same time.
8 REPLIES 8
Fixes: 524
Re: Are microfilters still required without telephony?
Technically , no. If you look at the schematic for a typical DSL filter, the DSL port is a direct connection to the line, all the filtering is on the phone side. Having said that, a DSL filter is probably the simplest way to convert the RJ11 to BT plug.
molerat
@MisterW wrote:Having said that, a DSL filter is probably the simplest way to convert the RJ11 to BT plug.
Or fit a NTE5C Mk4 faceplate with separate phone and VDSL sockets.  I believe if you already have an old single socket 5C the Mk4 filtered front plate is a straight swap.
G6JPG-0
Presumably, as the 'phone socket will become redundant, faceplated with only the VDSL socket will become available.
Fixes: 334
As most people, if they have the option, will be moving to FTTP, you won't need a phone socket - or the VDSL one.
G6JPG-0
I rather suspect there will be lots of customers who won't have the FTTP option - rural, awkward for other reasons, or awkward landlord (block of flats, campsites, other such) who won't allow access across their land/building to lay the fibre.
glocal
10 minutes walk from Deansgate at the centre of Manchester my building doesn't have FTTP. It will take a while for the whole country to get it.
I was hoping to get rid of that microswitch hanging from the BT point, but I suppose I will have to live with it for now.
HPsauce
Seasoned Pro
Fixes: 5
As noted in another thread I just hard-wired an RJ11 cable to the connectors on the backplate and clipped a simple shallow BT plate to the front. Really it now just needs a blanking plate! Are they available for the latest NTEs?
The plug-in filter, if used, only functions as an adapter between the BT socket and RJ11 cable to the router.
Fixes: 123
My understanding is that the Openreach Mk4 faceplate incorporates a RF filter which is there to increase line stability by reducing the effects of REIN (Repetitive Electrical Impulse Noise).
