Any update?
- Re: Any update?
Re: Any update?
16-09-2009 10:28 AM
Us Graham Napier fans have to stick together you know.........The things I'll say
Re: Any update?
16-09-2009 10:30 AM
http://www.samknows.com/broadband/exchange/CMWARW
Re: Any update?
16-09-2009 10:32 AM
Re: Any update?
16-09-2009 10:34 AM
Re: Any update?
14-10-2009 10:20 AM
My previous order was cancelled as my exchange was not enabled at the time, however, I’ve now received a text to say that my order has been submitted (ref 4350015943) but I’m not sure how to check if my exchange has been enabled in the meantime; how would I do this?
Many thanks
Rob
Re: Any update?
14-10-2009 10:22 AM
It's going to be a bit of a waiting game. Give us a shout in a month and we can try again.
Re: Any update?
14-10-2009 10:29 AM
Re: Any update?
14-10-2009 9:51 PM
http://usertools.plus.net/exchanges
up to date with the latest data. What I'll try and keep this page up to date:
http://community.plus.net/21cn-exchange-availability/
it looks a bit ugly at the moment, but I'll try and fix that. Note that unless it says Open on the exchange, we can't place any orders and the dates should only be used as a guide until it changes to Open.
Plusnet Technology
Re: Any update?
15-10-2009 9:35 AM
Now I am confused!
Using this link http://usertools.plus.net/exchanges/?exchange=Warwick&exact=1054&plugin=wbcdsl ; my Warwick exchange has a code of CMWARW, however, on this link http://community.plus.net/21cn-exchange-availability/ CMWARW is described as Milton Keynes! It can’t be both. CMWARW has a status of Open. This link http://www.samknows.com/broadband/exchange/CMWARW shows CMWARW as enabled 31/5/09 (if I’m reading it right) but my order to go onto the trial keeps being rejected I assume because the exchange is not enabled.
Would you please clarify the situation for me guys.
Rob
Re: Any update?
15-10-2009 9:42 AM
Apparently though, there's an inflight order glidepathing towards the critical hydraulic, preventing the flight completion of an ADSL2+ order.
Re: Any update?
15-10-2009 9:53 AM
I get the drift that something is currently stopping the order going through but I genuinely do have the first idea what that means, help!
Rob
Re: Any update?
15-10-2009 9:57 AM
Basically, it looks like ADSL2+ is available, but the ordering system seems to think that there is a voice or broadband order currently progressing which is preventing us from placing another broadband one.
Re: Any update?
15-10-2009 10:19 AM
As I’m sure you can confirm by checking my record with you, I have made no such request or order. How do we get ‘the system’ to understand that there are no orders outstanding? Apart from the one we are trying to get actioned of course.
Hope this isn’t coming across as narky, I have nothing but massive respect for the help that you give us James, just a bit miffed about what’s happening
Rob
Re: Any update?
15-10-2009 10:22 AM
Re: Any update?
15-10-2009 10:26 AM
