Any microfilter recommendations?
- Any microfilter recommendations?
29-10-2013 8:54 PM
The microfilters that came with the plusnet router only seem to be lasting a couple of weeks before my connection becomes very flaky, any recommendations for better quality ones? I'm currently using one i bought cheap off fleabay, i've only been with plusnet since september.
Message 1 of 6
(1,056 Views)
5 REPLIES 5
Re: Any microfilter recommendations?
29-10-2013 9:16 PM
If you have the router plugged into the master socket then I'd recommend one of these http://www.broadbandbuyer.co.uk/Shop/ShopDetail.asp?ProductID=9881
Message 2 of 6
(592 Views)
29-10-2013 9:25 PM
Forgot to mention, no master socket
Message 3 of 6
(592 Views)
29-10-2013 9:27 PM
+1 for the ADSLNation XTE-2005
As you are not using the master socket, then I would try these - ADSLNation XF-1e Professional ADSL2+ Microfilter
Message 4 of 6
(592 Views)
29-10-2013 10:22 PM
Thanks, i think i might order one
Message 5 of 6
(592 Views)
30-10-2013 10:54 AM
Are you having issues with both microfilters we sent, is the one you've bought working OK?
Message 6 of 6
(592 Views)
