Another slow guy here
outtasync
I have noticed the past few weeks having a lot of buffering when scrubbing through videos so the last few days I have done a few speed tests.  Speeds seem to be well down.
Have restarted/reset the modem.  Tested wifi/ethernet.  Plugged into test sock.  Disconnected all devices.
I think its time for some tech support.
Is there anybody here that can check my line and run some tests.  I may not be able to call within your opening times for a few days depending on work so any remote help on here would be greatly appreciated.
I have attached screenshotshot from speedtest and bufferbloat
*edit*  Just to add to this the speed fluctuates wildly, even during the short speedtests, from3/4 to 30/35.  Not stable from one moment to the other
4 REPLIES 4
Fixes: 382
Re: Another slow guy here
@outtasync Welcome to the forums, What package are you on? You do appear to have a problem, but a structured approach to sorting it would help.
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub (with the 'Username' obscured) would be a good starting point.
For the Hub One -
For the Hub Two -
SammyM
Fixes: 101
Hiya @outtasync
I'm really sorry you are having an issue with your speed and for the hassle this is causing.
The speed is showing within estimates on our side and it isn't picking up any external faults.
I want to get to the bottom of this, can you follow the instructions that @jab1 has mentioned so we can see what the speed is on a wired connection.
 Sammy M - Sheffield Team
outtasync
Hi and thank you for the replies and looking into everything.
Due to some refurbishment I had to turn my router off for 24 hours after writing my initial post and have noticed that speeds have been steady for the last few days.
I have no idea if this was related to not having it powered on for prolonged period of time or just coincidence.  Hopefully this will be the end of the matter.  Definitly unless it starts happening again there is nothing we can investigate.
So for now thank you all for your help and replies and hope not to bother you again.
Fixes: 382
Quite conceivably.
