Android Phone e-mail
- Android Phone e-mail
26-09-2011 7:27 AM
Settings I have are
smtp relay.plus.net
security none
Port 25
require sign in ticked
username usual
passwrod usual
It checks outgoing settings and goes through ok
E-mails go but never arrive ---
I'm on contract with T- mobile if this helps.
Andrew
Re: Android Phone e-mail
26-09-2011 9:11 AM
Are the e-mails going to the "Sent" folder on your 'phone or are they in your "Outbox"?
Bob
26-09-2011 3:00 PM
26-09-2011 3:15 PM
Bob.
26-09-2011 9:48 PM
The e-mails I have sent have left the out box in other words nothing there.
I'm a bit new to this -- so how do you send e-mails by wi fi only? sorry to be dim.
I've changed to the t-mobile settings but it says can't connect to server, so doesn't get as far as the plus net settings.
so that's not it I'm afraid
cheers
Andrew
27-09-2011 8:58 AM
To test sending e-mails on wi-fi, go to Menu > Settings > Wireless & networks and make sure that under the Wi-Fi setting you are connected to a wi-fi network (it should say “Connected to wireless network name”). Also make sure that the Mobile network setting is not ticked (this is further down the page). This will force the phone to use wi-fi networks only and your phone should display a symbol like the one in the attached image in the notification bar.
I’m assuming that you have a home wireless network connected to PlusNet. Can you test if you can send an e-mail from this.
Bob
27-09-2011 7:17 PM
Thanks again -- so all e-mail I have tried to send can be seen in the sent box, I have no trouble with e-mails through my main computer and laptop, ( plusnet account ) the android phone seems to be the stumbling block..
The symbol is there and connected --- I can't see anywhere that says Mobile Network.
On Wi-Fi settings page I have
Wi- Fi ---- shows connected
Network notification ---- ticked
WPS button connection --- says configure wireless networks automatically.
THEN
Wi - Fi networks
shows my connected network and scans for others, can see a few others.
Andrew
28-09-2011 8:44 AM
The only think I can suggest is to delete the PlusNet mail account from your mobile and recreate it from scratch – unless anyone else has any ideas?
Bob
28-09-2011 9:59 AM
28-09-2011 10:39 AM
Bob.
28-09-2011 1:47 PM
Passes the authentication test Ok... mail disappears from Outbox into Sent, but doesn't arrive at Plusnet.
Using WiFi with the same setting works Ok.
So someone is blocking port 25 - have tested this on a Gradwell broadband connection and it works Ok, so must be Vodaphone...
don't suppose Plusnet allow use of an alternate port?
28-09-2011 2:17 PM
Bob.
28-09-2011 3:38 PM
Quote from: knowdice Andrew - using the same settings as you on Vodaphone doesn't work either
Works fine for me on pay monthly Vodafone. I've just set it up and sent a test email to a Plusnet email address, my work email address and a third party email address and all three arrived almost instantaneously.
28-09-2011 3:54 PM
Just tested again and it works on Vodaphone data and Plusnet via WiFi so don't know what was going on...
My settings are:
SMTP server - relay.plus.net
Security type - None
Port - 25
Require sign-in - Ticked
Put in User name and Password - passes initial test.
Send email - leaves Outbox and shows in Sent.
This is on a Samsung Galaxy S2...
28-09-2011 4:17 PM
Quote from: knowdice This is on a Samsung Galaxy S2...
Just for the record, I tried (and succeeded) using a ZTE Blade (Orange San Franciso) running Android 2.2.
