Speedtest.net fault
- Speedtest.net fault
Speedtest.net fault
28-09-2011 1:24 PM
Re: Speedtest.net fault
28-09-2011 1:44 PM
28-09-2011 1:56 PM
edit I'm using Chrome
To be is to do - Kant
do be do be do - Sinatra
28-09-2011 2:17 PM
28-09-2011 4:08 PM
Trouble is it doesn't seem possible to make contact with Speedtest as I only get an automated reply.
28-09-2011 4:21 PM
Just done four test, but I dont have an account
28-09-2011 4:31 PM
28-09-2011 4:34 PM
28-09-2011 6:08 PM
28-09-2011 7:07 PM
worked for me to
28-09-2011 9:31 PM
29-09-2011 12:43 AM
Which is curious as Plusnet show my line speed as 6mb. "My broadband speed" agrees with the above test and the BT speedtest also shows around 6.2
A week ago it was showing what you would expect around 5.8. BT speed has been around the odd ip 6501 past couple of weeks.
I was wondering if the past weeks jump is behind the scenes Plusnet tinkering in preparation for the odd ip's? I know JP said Plusnet would simply bump up to the next speed to allow for the odd bit but would it show that. Or would it show the usual speed with the odd bit added behind the scenes as it appears here?
It would certainly make better PR. A "faster" than your connection speed rather than a much slower one.
