Am I using the best configuration (for my needs)?
- Re: Am I using the best configuration (for my need...
13-05-2013 10:44 AM
Hi all
My Technicolor 582n Modem/Router is connected to a TP-Link TD-W8968 Modem/Router so I can use the TP-Link for Wireless duties.
The TP-Link's IP Address has been changed to a static IP Address and DHCP is Disabled.
All is working fine, and I only need to switch on the TP-Link when I need Wireless, but Is there a better configuration I should consider?
Would appreciate any suggestions or comments.
Message 1 of 3
(691 Views)
2 REPLIES 2
Re: Am I using the best configuration (for my needs)?
13-05-2013 11:33 AM
It depends on what you seek to achieve. Given your description, I'm guessing you are seeking to be able to switch off wireless when you dont need it - why? Or are you looking for 'better' wireless than that delivered by the 582n?
I assume that the 582n is the device connected to the phone line (rather than the TD-W8968)?
I also assume that you have switched off wireless support on the 582n?
Message 2 of 3
(396 Views)
13-05-2013 12:12 PM
Hi townman
Switching off wireless when I don't need it can be done on either device but, IMO, the TP-Lnk does provide a better wireless experience and I only switch it on when I need wireless.
Yes, the 582n is the device connected to the phone line.
Only switched off wireless support on the 582n by way of the top/front on/off button.
I suppose I'm just thinking would it be worth setting up the 582n as a Modem only (PPPoE ?) and using the TP-Link as a Router/Wireless Router.
My guess would be no if only one or two people use the connection at the same time but yes/possibly for more than say four users.
Also would the 582n react/work noticeable faster if only using it's processing 'power' for modem duties?
I have also tried several times to setup/use my Netgear DG834GT without success and maybe using a PPPoE setting, in conjunction with the TP-Link, would be worth trying.
Looking for thoughts/opinions from you and members who know more about these things than I do.
Message 3 of 3
(396 Views)
