Am I "suffering" the missing 2.5 Mbps?
- Am I "suffering" the missing 2.5 Mbps?
Re: Am I "suffering" the missing 2.5 Mbps?
20-02-2012 3:31 PM
20-02-2012 5:00 PM
I've had 60Mb out of speedtest.net before now, it's a spurious result so I just delete it. The real ones are consistently the same speed, 37.5Mbps.
Quote from: fagin Although my speed fluctuates dependant on time of day, this kind of speed is not uncommon on my connection and my PN Profile is set at 37mb.
20-02-2012 7:35 PM
20-02-2012 8:27 PM
Quote from: _Adam_Walker_ it's nice to see a fibre speed test actually above 40mb, that's not an invite for Bob Pullen to start showing off by the way
I thought it was actually impossible on FTTC Adam
Edited to add - Unless you are on an 80/20 trial and in which case that would be a very poor result.
20-02-2012 8:33 PM
21-02-2012 2:09 PM
21-02-2012 3:03 PM
To find out the IP Profile value, use the speed tester at http://www.speedtester.bt.com/ (but NOT the beta version). That will tell you a profile value for both upstream and downstream.
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
21-02-2012 3:33 PM
Quote from: WWWombat To find out the IP Profile value, use the speed tester at http://www.speedtester.bt.com/ (but NOT the beta version). That will tell you a profile value for both upstream and downstream.
Thanks WWWombat. I thought this tool reported the IP profile, too, but when I run it (the non-beta version), the output is simply:
1. Best Effort Test:
Download Speed : 34 Mbps
2. Upstream Test:
Upload Speed : 1.98 Mbps
However, this is telling in itself, and it looks like I am suffering from the missing MB, because the engineer's test showed a line speed of 39998kbps.
JoJo, or Plusnet staff - please can you work your magic on this with the 20Mb profile?
Thanks very much,
Gary
21-02-2012 4:09 PM
just done that. It should take effect in the next 15 minutes. Let me know if you see any difference.
Jojo
21-02-2012 4:23 PM
Quote from: Joanne just done that. It should take effect in the next 15 minutes. Let me know if you see any difference.
Thanks, Jo - you're a star! It made a difference almost immediately. Jumped from about 33Mb speedtest to 38Mb!
Just out of curiosity, can you tell me more about how this fix works? Of course, it's entirely counterintuitive that a 20Mb profile gives me a faster speed than the 37Mb profile did!
21-02-2012 4:37 PM
21-02-2012 4:50 PM
22-02-2012 9:41 AM
Jojo
22-02-2012 10:57 AM
22-02-2012 1:24 PM
