Am I "suffering" the missing 2.5 Mbps?
- Am I "suffering" the missing 2.5 Mbps?
17-02-2012 2:22 PM
Quote Download speed achieved during the test was - 34 Mbps
For your connection, the acceptable range of speeds is 12 Mbps-38.72 Mbps .
Additional Information:
IP Profile for your line is - 38.72 Mbps
However, if easily fixed I should be gratefull
Re: Am I "suffering" the missing 2.5 Mbps?
17-02-2012 3:31 PM
I've put you on a profile we used for our trialists and see if that makes a difference. It can take about 15 minutes or so to take effect though. Let me know if you see any increase.
Jojo
17-02-2012 3:42 PM
Woulld there any merit in you doing the same for me as I think I am seeing the same issue as Adajio. Also see http://community.plus.net/forum/index.php/topic,102285.msg871842.html#msg871842?
TIA. Chris
17-02-2012 4:00 PM
Quote from: Joanne
Bingo - my missing 2.5 Mbps back
Quote Download speed achieved during the test was - 37 Mbps
Jojo you are truly a star Thank you.
17-02-2012 5:01 PM
Glad to know that works, it'll give us something to go on.
Hi chrisjbzero,
I've done that now, should take about 15 minutes.
Jojo
17-02-2012 5:03 PM
17-02-2012 5:07 PM
17-02-2012 5:09 PM
17-02-2012 5:11 PM
17-02-2012 5:13 PM
In which case can I go back to that too please...
17-02-2012 5:25 PM
17-02-2012 6:18 PM
Regards Chris
18-02-2012 1:10 AM
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
18-02-2012 1:02 PM
18-02-2012 1:14 PM
