Alleged Problems with Openreach
dmd444
Re: Alleged Problems with Openreach
Yes.
corringham
Seasoned Champion
Fixes: 23
@dmd444, you have the "ADSL broadband" label set - do you currently have ADSL?  If you do have ADSL, there is a chance that there is no FTTC or FTTP available at your address - if that is the case Vodafone won't be able to offer any broadband, and that would explain their response.
@corringham wrote:
" there is a chance that there is no FTTC or FTTP available at your address - if that is the case Vodafone won't be able to offer any broadband,"
Unless CityFibre, (or another AltNet), is available in @dmd444's area?
Vodaphone FTTP is available in my area, but only via CityFibre - Openreach FTTP hasn't reached us yet.
Fixes: 384
Point of order, @Anonymous  - CF aren't an altnet, but an infrastructure provider.
@jab1
"Point of order, @Mr_Paul  - CF aren't an altnet, but an infrastructure provider."
Isn't "AltNet" the generally accepted abbreviation on these forums for "Alternative Network"?
"Network", meaning the network infrastructure.
That being the case, I would say that CityFibre are an "AltNet".
ISPs - which I assume you are calling "AltNets", are "Internet Service Providers".
Fixes: 384
Depends on your interpretation, I suppose - 'Trooli', for instance , are an 'altnet', but you can only get a service from them over their network - try getting a connection to TalkTalk, for instance, when connected to them.
@jab1
"Trooli', for instance , are an 'altnet', but you can only get a service from them over their network - try getting a connection to TalkTalk, for instance, when connected to them."
So Trooli are both an Alternative Network, "AltNet", and an Internet Service Provider, "ISP", then?
Fixes: 384
The same could be said of many other providers, but CF are not an ISP.
@jab1
"The same could be said of many other providers, but CF are not an ISP."
I never said they were.
Isn't this where we started????
Fixes: 384
OK - we are deviating from the topic, and I'm not in the mood for semantics, so...
