Akamai and streaming data - traffic management problem(s) are NOT fixed :-(
mikeb
In fact, not only is the most recent traffic management problem most definitely NOT FIXED despite service.status claims to the contrary, it is actually significantly worse tonight than it has been earlier in the week ... and it was way bad enough then !!!
Streaming media (and 4oD in particular) is 100% unusable tonight as opposed to most things being around 90% unusable for significant periods of time as they have been since the problem first started.  As per bleedin' usual, this problem very much appears to be due solely to PN quite unreasonably and totally unjustifiably throttling AKAMAI traffic to near zero data transfer rates for some (but not necessarily all) users Sad Sad Sad
The following netmeter graph demonstrates and positively confirms the problem occurring right now:
Do you see that tiny weeny little line showing data transfer at sub dial-up speeds ? Well that's Akamai streaming video data for 4oD programmes, all 4oD programmes that I've tried.  The other somewhat more reasonable looking data transfer is for certain adverts and general web traffic etc.  In addition to this, some adverts from some other Ad houses and/or media hosts are simply not working at all so there is either just a great long pause of nothingness where the relevant Ad servers should be sending data or the expected adverts are missing completely.
Streaming data in general (and 40D in particular) has once again been virtually unusable ever since this repeat performance of previous remarkably similar problems occurred.  Somewhere around 2 seconds of video followed by around10 secs of buffering (repeated ad infinitum for ALL programmes tried) tends to somewhat spoil the overall viewing experience and all that Angry
EDIT:
The Akamai server used above was "b.scorecardresearch.com" [84.53.138.27 or 84.53.138.32] AKA "a1294.w20.akamai.net"
PLEASE ALSO NOTE before adding "everything is working perfectly OK for me" stylee comments that some users may be fortunate enough to not be suffering with the latest problem(s) and in addition, some 4oD programmes being streamed to some users may also be being served from totally different sources. Just because everything is working for you doesn't mean that it's working for everyone else Smiley
B T Plusnet, a bit kinda like P T Barnum ...
... but quite often appears to feature more clowns Tongue
55 REPLIES 55
houlton23
Re: Akamai and streaming data - traffic management problem(s) are NOT fixed :-(
It's a long shot but have you rebooted since the issues last week?
You could still be on a default traffic management profile which would explain the Streaming throttling you are seeing?
Alex Smiley
mikeb
Hmmmm *good* point, I generally try a quicky PPP termination and re-establish a shiny new connection first before whining profusely but have to admit that I haven't done on this particular occasion  Embarrassed
Thanks Smiley will try a bit later on to see if changing gateway and/or obtaining a 'new' TM profile helps in any way at all.  It hasn't on all previous occasions that this recurring problem with Akamai and Premier A/C users in particular has cropped up ... but PN and Traffic Management work in mysterious ways and all that so you never know !
mikeb
Tracert to Akamai server on the original PPP connection used for above graph:
1 0 ms 192.168.1.1 Router-adsl
2 32 ms 195.166.130.73 lo0-central4.ptn-ag01.plus.net
3 46 ms 84.93.253.3 - - -
4 * * no response * - - -
5 32 ms 195.166.129.39 po2.ptw-gw02.plus.net
6 * * no response * - - -
7 31 ms 84.53.138.27 - - -
-or-
2 31 ms 195.166.130.73 lo0-central4.ptn-ag01.plus.net
3 32 ms 84.93.253.3 - - -
5 31 ms 88.221.84.42 a88-221-84-42.deploy.akamaitechnologies.com
I have no idea why tracerts are occasionally different when performing multiple checks but this could well be indicative of an associated PN DNS issue as has also occurred recently for several other domains and has occurred previously for various channel4 domains.
Trtacert to Akamai server on shiny new PPP connection:
2 32 ms 195.166.128.202 lo0-central1.ptn-ag01.plus.net
3 47 ms 84.92.3.137 gi2-6-111.ptn-gw01.plus.net
5 * * no response * - - -
6 31 ms 212.159.1.135 po4.ptw-gw02.plus.net
7 * * no response * - - -
8 47 ms 84.53.138.27 - - -
RESULT: No significant difference and if anything the problem(s) are marginally worse on the new connection when compared to the transfer rates shown in my first post Sad  General data transfer rate is somewhat lower and more erratic than previously for most things and especially so for the all-important streaming data from Akamai.
Apparently there are exactly the same problem(s) with ITVplayer and BBC iplayer whilst working somewhat better is still considerably lower quality than usual and has frequent pauses for buffering.   Generally speaking, streaming video is still completely stuffed during peak hours no matter what ... but it will no doubt be reasonably OK again just after midnight when traffic management changes take place ... so watch this space for the evidence to most likely prove it Wink
This is almost certainly yet another repeat performance of numerous previous problems where Akamai data in particular is being quite intentionally and totally unreasonably killed by PN for some users on some A/C types .
Nice one PN ... Grrrrrrrrrrrr  Angry
RichardB
Seasoned Champion
Fixes: 39
Out of interest I have just tried watching Time Team on 4OD.
I did not have any problems watching the first few minutes of the programme.
Maybe the issues are related to the PN gateway?
The usertools gateway checker http://usertools.plus.net/@gateway/ reports:
You are currently connected to the gateway known as pcl-ag08.
Richard
VeryAngry
I cannot stream anything since joining Plusnet a week ago so have lost all Internet TV and cannot use my Love Film subscription.
It is ridiculous and annoying that if I want to be able to watch films and TV again on the internet I have to pay almost 200 quid to come out of a contract so I can go with back with my old iSP.
Seven days I have had this service and it is utter rubbish!
mikeb
Well guess what ... yup, it's now just after midnight and 4oD is making a halfway reasonable attempt at working  Roll_eyes  HOWEVER, performance is still poor even compared to what I would consider as 'normal' relatively poor performance when using PN.
No further changes in gateway or indeed anything else whatsoever from earlier on but exactly the same programme streaming now looks like this:
Still pretty poor really with significantly lower BW than is usual for PN and not even remotely close to what is actually appropriate for my connection when downloading data from Akamai servers of course.
BTW, the last identical occurrence of this particular problem was reported HERE and if my logfiles are anything to go by, a good many peeps have been reading this ancient old thread just recently, presumably after searching for "4oD streaming problems" or similar.  There is quite obviously absolutely no way anyone would be reading a 9 month old message board thread over the past week for the first time in 9 months ... unless they just happened to have stumbled across it whilst looking for any information about similar problems !  Kinda proves that a good many other users are also experiencing these problems but are not actually posting about them doesn't it ?
I wonder when PN are going to learn to:
(a) Not quite intentionally break websites who pay no doubt very large sums of money to the likes of Akamai in order to ensure that their content is delivered to their customers at full speed, top quality and without any undue performance issues in general ?
(b) Having been found out breaking things once again, acknowledge the c*ckup immediately and then fix the fundamental problem in a timely manner without any totally unnecessary arguments, denials, excuses or finger pointing to "our suppliers" or whatever ?
(c) Test things properly before hitting that big shiny 'deploy' button to avoid dumping a whole load of untested tweaks and/or other problems on unsuspecting paying customers ?
@veryangry: I'm sure your user name says it all - and quite rightly so - however I would strongly suspect that your problems are primarily down to something else such as a genuine line fault or some weird setup/configuration problem.  The problem discussed in this thread is most likely to only be affecting users with old accounts and in any case it is really only seriously affecting data coming from quite specific sources. If your connection speed or download rate is varying wildly as you mention in the other thread then this would tend to suggest a much more fundamental problem with your connection in general. Hope you can get it sorted very soon Smiley
VeryAngry
Somone else has said I should not get your problem on FIbre. So I have raised a line fault and shall see where it leads me, thanks.
jojopillo
Hi mikeb.
Would you be able to get us a wireshark capture and some speed tests?
Jojo Smiley
Kelly
Fixes: 9
Hey MikeB.
Thanks for giving us a heads up.  I always appreciate the detail you give us on this sort of stuff.  We'll try and work out what going on and get it fixed.  Streaming *should* be fine.  We believe the TM platform is working correctly after the problems last week and our call volumes support that, but it's possible that you might be affected by a lingering issue we haven't spotted, or just genuinely have a fault.  Either way, we'll get to the bottom of it!
Kelly Dorset
Ex-Broadband Service Manager
sjrinfroyle
I am having problems with streaming as well, YouTube works if I refresh the page about three times, but yesterday it stopped working so I gave up.
However, my line is under-performing at the moment, I am only getting 3Mb/s.
cmarks
I am having problems streaming radio from BBC.  Keeps buffering.  All usual tests show the line is fine (engineers have been out testing recently for line noise problem which has been fixed).  Now get radio buffering every minute or so even though I have about 6meg down stream speed (on a line synched at 16meg).
Is this related to above?
jojopillo
Hi cmarks,
This type of thing could have many causes. More information would help. what radio station are you streaming? What time is it happening? How often does it happen? Is there anything else running on your computer that may slow it down? Have you tried running it with no other programs, tabs or browsers open? That's not an exhaustive list but as much information as possible would help.
Jojo Smiley
Force9Original
WinMTR  might be  another useful tool ?
http://winmtr.net/
Cheers f9o
orbrey
Hi cmarks,
Streaming radio uses hardly any bandwidth at all, nowhere near as much as video does. If it's stuttering it may well be worth trying something as simple as using a different browser to see if that makes a difference. Hope things have improved since Jojo's suggestions above, please let us know if not?
