Advice Please on reconnection
TW
My neighbour is cutting a tree down.
BT has been engaged to take the phone-line to my house down for a few hours and then reconnect to avoid damage to the line.
This shows my connections:-
I have Unlimited Fibre, with copper to the house
I can reach the power supply to the OpenReach box fairly easily but have mobility difficulties
What steps should I take to disconnect and reconnect please?
8 REPLIES 8
Fixes: 466
Re: Advice Please on reconnection
@TW
There should be no need to do anything. It should just reconnect automatically.
Moderator's Note
This topic has been moved from Full Fibre to Broadband
Fixes: 358
@TW You should not have to take any steps. You should reconnect automatically when the line is restored.
If it was me,  I'd just pull the DSL cable out of the phone master socket, and then put it back after the work is done.
If you really wanted to be pedantic, you could log in to your router's web interface, and then click on <Disconnect> associated with the PPPoE WAN connection, and then wait 5 minutes before pulling the DSL cable out of the master socket.
Fixes: 240
What is the risk that one seeks to mitigate here?
Probably trying to avoid DLM banding if the disconnection isn't a clean break ?
TW
@Niburu
Thanks for the clear and explicit adv9ce
@Townman
I have had problems with my connection speeds, sometimes without apparent reason. This is what I wanted to guard against.
@Baldrick1 and @jab1
Thanks for the advice that doing nothing is OK!
That is the line I shall take as it is easiest for me.
My apologies for misinterpreting my connection as Full Fibre and hence posting in the wrong forum section.
I shall wait and see if all is well after reconnection tomorrow!
Good luck ! - I'm sure it'll be fine if you do nothing, and if you do get a speed drop then just ask Plusnet for a line DLM reset.
TW
Reconnected!
Thank you all for your help.
As predicted automatic reconnection was without incident and with speed maintained at the upper limit of the estimated download range.(36 - 40Mbps)
Reconnection occurred today largely owing to the help with OpenReach that Plusnet provided for me by telephone,
No thanks to Openreach who failed abysmally to fulfill their agreement for reinistallation of my phone line within the agreed time limits.
