ADSL2+ upgrade times
- ADSL2+ upgrade times
Re: ADSL2+ upgrade times
17-11-2012 10:44 AM
17-11-2012 10:57 AM
19-11-2012 11:36 AM
I can see that the order for ADSL2+ has completed, how are things your side?
19-11-2012 12:04 PM
19-11-2012 12:12 PM
You might find the current line speed on this page needs updating to match your new IP Profile speed which will be 88.2% of your sync speed.
19-11-2012 1:03 PM
might still need resetting as currently sill shows as :
Telephone number:xxxxxxxxxxx
Phone exchange:PEVENSEY MARINA
Estimated line speed:7Mb (Accurate to within +/- 1Mbit)
Checked on 2012-09-16 15:14:43Current line speed: 6.5 Mb
19-11-2012 5:48 PM
Once again cheers chaps for your continued help !
19-11-2012 5:55 PM
19-11-2012 6:05 PM
Download Speed
5.96 Mbps
0 Mbps 7.15 Mbps
Max Achievable Speed
Download speedachieved during the test was - 5.96 Mbps
For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
Additional Information:
Your DSL Connection Rate :7.62 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 6.5 Mbps
19-11-2012 6:11 PM
Can you post the stats from your router please. (including specifically sync speed, attenuation and noise margin)
19-11-2012 6:17 PM
System Up Time 00:30:22
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN pppoa 38776 61928 0 3688 43891 00:30:07
LAN1 Link Down 63285 40711 0 43442 4621 --
LAN2 10M/100M 00:30:14
LAN3 Link Down --
LAN4 Link Down --
WLAN 300M 8831 7239 0 2849 697 00:29:57
ADSL Link Downstream Upstream
Connection Speed 7616 kbps 448 kbps
Line Attenuation 8.0 db 17.0 db
Noise Margin 7.8 db 25.0 db
ADSL Firmware Version A2pB025c1.d21j2
Modem Status connected
DownStream Connection Speed 7616 kbps
UpStream Connection Speed 448 kbps
VPI 0
VCI 38
19-11-2012 6:23 PM
19-11-2012 6:30 PM
19-11-2012 6:36 PM
19-11-2012 8:29 PM
